Craftsman lock nut - Router Forums
post #1 of 11 (permalink) Old 01-10-2017, 11:56 AM Thread Starter
First Name: Dick
Default Craftsman lock nut
I have a old Craftsman router. Model 315-17370. The lock nut has broken. Part # 1-623793-01. I know that some other Craftsman routers used the same lock nut. Example: model 315-17480 and maybe other models as well. I have been on the Internet and have been unable to find a replacement. All the sites say that the part is discontinued. Is there anyone out there that knows of a place where I can buy a new one ?? Or is there someone that has an old Craftsman router that is no longer working but has a good lock nut that I could buy from them. Any help or information would be greatly appreciated.
icansee is offline
post #2 of 11 (permalink) Old 01-10-2017, 12:09 PM
Hi Dick and welcome. Ryobi made your router and I doubt they made that nut. It was probably an off the shelf item somewhere. Have you tried a tool repair shop? They might know where to find something that will work. I doubt if there is anything super special about it. It may just need to be the right diameter and thread pitch. If it needs to be thinner than what you can find you can grind one down to the correct thickness.
post #3 of 11 (permalink) Old 01-10-2017, 01:29 PM
Dick You might find what you need at McMaster-Carr.
https://www.mcmaster.com/#hex-locknuts/=15ur2f9
https://www.mcmaster.com/#thumb-nuts/=15us9mu
Herb Stoops is online now
post #4 of 11 (permalink) Old 01-10-2017, 01:40 PM
Knothead47's Avatar
Do you know or have the diameter and thread pitch? Need that to identify it.
John T.
My wife gives sound advice. 99% sound and 1% advice.
Knothead47 is offline
post #5 of 11 (permalink) Old 01-11-2017, 06:18 AM
Northerner26's Avatar
First Name: Kevin
if you run out of all options you could probably have one made at a machine shop? but for the price of doing that you should just buy a new router which will have parts available for a long time! good luck
"I pledge allegiance to the flag of the United States of America, and to the republic for which it stands, one nation under God, indivisible, with liberty and justice for all."
Northerner26 is offline
post #6 of 11 (permalink) Old 01-11-2017, 07:16 AM
First Name: dave
try Renovo Parts 248) 634-6234
davidpatrick is offline
post #7 of 11 (permalink) Old 01-11-2017, 12:05 PM
Hi Dave and welcome. Thanks for posting the information.
post #8 of 11 (permalink) Old 01-11-2017, 12:12 PM
JOAT's Avatar
First Name: Theo
I have 4 or 5 old Craftsman routers, and no none are for sale. I had to replace one on one of my routers years ago, got a bolt and wingnut from the local hardware, cost somewhere under $1. Still working just fine.
NC via the Army in 1979; retired 1981, just east of Raleigh ever since.
Remember, when I tell how I do something, that does not mean I recommend you do it my way. Different backgrounds, experiences; what works for me, may not for you.
No point in believing in things that exist. If they exist, you don't have to believe, they just are.
JOAT is offline
post #9 of 11 (permalink) Old 01-12-2017, 09:26 AM Thread Starter
First Name: Dick
Hi Chuck:
Thank you for your input.
Dick
icansee is offline
post #10 of 11 (permalink) Old 01-12-2017, 09:42 AM Thread Starter
First Name: Dick
Hi all:
The so called "LOCK NUT" is actually not a "nut" at all. It is not threaded. It is a 6 sided piece that has a recess cut into it, that allows a locking finger to grab it, to keep the motor shaft from turning as you tighten the bit collet. The inside of the "lock Nut" is tapered to fit the motor shaft snug and then there is a nut that holds it in place. I am sure I cold have one made (for a cost that would far exceed the value of the router). But I though that with all the Craftsman 315 series routers out there, that someone would know of a place to buy a replacement "Lock Nut" or someone would have an old router that no longer worked and would be willing to sell the nut to me.
Dick
icansee is offline
Human Verification
COLLATE NUT Craftsman 315.17480 dhw Tools and Woodworking 5 07-20-2015 01:08 AM
collet nut for Craftsman router mdl#315.17480 freed General Routing 11 09-14-2014 11:21 PM
Very rusty collet and nut in Craftsman. Possible rehab? Goblu General Routing 8 05-09-2014 07:53 PM
Repairing Older Craftsman Shaft Locks MEBCWD Woodworking Articles 0 03-08-2012 07:55 PM
need a lock nut sgmex Introductions 6 08-21-2008 05:57 PM
