Thread Tools Display Modes
Old 03-28-2005, 07:15 PM   #1
ryan.s
Member
ryan.s is on a distinguished road
Default Anyone use their router on metals?
Another newbie question. I know this is general routing under the general woodworking section but didn't know where else to turn. I did a search on google and couldn't find any info so I thought I'd ask you guys. Would it be possible to use the router on metal, maybe a soft metal like aluminum. Have any of you guys tried it? From the little that I found I guess you need an "end mill bit"? The problem is the end mill bits I found all had 3/8 " shanks. I guess they weren't meant for hand held routers. If someone can shed some light on the whole "routing metal" topic I would appreciate it. I wonder if a carbide spiral bit would work.
ryan.s is offline   Top - Reply with Quote
Old 03-29-2005, 10:08 AM   #2
jerrymayfield
Forum Geek
You can rout most non ferrous metals. I use solid carbide spiral end mills,they are available in 1/4" and 1/2" shanks and 3/8" collets are available for PC routers. If you don't have a PC router adapters are also available.
Good Luck
jerry
Old 03-29-2005, 11:09 AM   #3
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Bosch also has 3/8" collets available.
Old 03-29-2005, 05:31 PM   #4
Thom2
Jr. Member
Thom2 is on a distinguished road
Send a message via ICQ to Thom2 Send a message via AIM to Thom2 Send a message via MSN to Thom2 Send a message via Yahoo to Thom2
I make these push sticks from 1/8" aluminum sheet using a BS to rough cut the blanks and then using a vacuum clamping jig and a flush trim bit to make near perfect copies.
Carbide bits will indeed do a fine job on aluminum, I've worked with a few small rabbets on 1/4" bar stock and done a good bit of flush trim work with the 1/8". I haven't tried plowing any dadoes yet, but wouldn't hesitate to at least try it.
A few words of caution:
1. use lots of candle wax as a lubricant for cutting aluminum
2. wear long sleeve shirts and any safety gear you have, these chips REALLY fly and can sting, as well as being hot.
3. don't let the wife walk barefoot thru your shop to get the newspaper DAMHIKT
4. SUPPORT THE STOCK!!!! ... push blocks, featherboards, vise grips, WHATEVER IT TAKES! this ain't wood that's gonna get thrown at ya if you slip!!!
DC probably isn't a bad idea, I've nicknamed my shop 'tinsel town' after seeing what it looks like when I make a dozen or so of these at a clip.
HTH
Thom
maker of quality tinsel in PA
Thom2 is offline   Top - Reply with Quote
Old 04-02-2005, 05:36 PM   #5
TomB
Jr. Member
TomB is on a distinguished road
the aluminum window industry uses 1/4 inch router cutters one possible source is www.trend-usa.com
(although tonight i cant see any router bits at all on the site for some reason?! )
TomB is offline   Top - Reply with Quote
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
New Router my way reible General Routing 14 06-10-2006 11:19 PM
