Thread Tools Display Modes
Old 03-28-2005, 09:59 PM   #1
Drick
Member
Drick is on a distinguished road
Talking Square fence
Hey guys,
If you want a fence that is easy to keep square to your router table, try using a speed square. Home Depot has a large one that is made of plastic. Clamp the side of the right angle that has the lip on it to the front or side of the table. I use a bar clamp between the front and back of the table to hold the square's lip tight against the table. Add a C-clamp to help hold the square down. Put the other side of the square's right angle adjacent to the bit. Use a second square, one of the adjustable ones with a ruler, to measure from the fence to the bit. You can also use the square as a way to check the squareness of your regular fence.
Drick is offline   Top - Reply with Quote
Old 03-29-2005, 12:12 AM   #2
reible
Supreme Forum King
reible's Avatar
Hi, interesting ideas..... boy I don't know how to say this but I never square my fence. I don't because with a router or drill press or any tool like these the fence does not have to be square to the table....... Check out this post and get back to me if you need to... sometime it's just how you think of things that makes all the difference.....
www.routerforums.com/showthread.php?t=521
Ed
Old 03-29-2005, 09:13 PM   #3
Cummins92
New Member
Cummins92 is an unknown quantity at this point
reible,
It might depend on how a person wants to use their router table. I would really like to own a wood milling machine, but can't afford it. So, with parallel table sides, square miter slot, router lifter, router fence with gib adjustments, surface gage with an indicator, and dial calipers I can play wood mill until I hit the Lotto. I have fun playing with it, others might not. But, thats the thing, have fun with the hobby.
Cummins92 is offline   Top - Reply with Quote
Old 03-29-2005, 11:28 PM   #4
reible
Supreme Forum King
reible's Avatar
Originally Posted by Cummins92
reible,
My intent was not to say one can't do what ever they want but I just have seen so many people who have been woodworker for years trying to square a fence to the router table... I show them that it doesn't matter and this light bulb turns on!!! It is amazing to see! Tables are often even designed with marker etched in reinforcing the notion of having to have it on the same measurement on both sides.... I don't think anyone I've shown this to has ever gone back......
I worked in a machine shop a long while back and I did a bridge for a guitar on a mill. I to have often wanted that capacity again but no funds thus far for this dream. I have even thought about just a x-y table to mount on a drill press and using it as a slow router (I even have a collet for the drill press as a drill chuck is not designed for the forces of routing).
How about sending a picture of your set-up?
Ed
Old 03-30-2005, 09:26 AM   #5
Cummins92
New Member
Ed
I'd like to send a photo, but the money for a digital camera that I don't have would go towards that wood mill. Even a free Bridgeport would do. My table is basically Norm's with "Formica" on all surfaces. A lot of time spent on making the sides parallel, but that's all related to my job. The fence is higher and longer and clamps over each side with screw adjustments for side play. Maybe I should spend more time on things that pay money and buy that wood mill. By the way, maybe you should reconsider your concerns about that drill chuck. We do mill with them, just be gentle. In closing, I wasn't questioning the motives of your reply. I just wanted to present a different view. Thank You and have fun.
Old 03-30-2005, 03:17 PM   #6
reible
Supreme Forum King
reible's Avatar
From what you are saying this table and you are part of a commerical shop then? If so I can understand if you don't want to answer some more questions but I am interested in just what you are doing and how you are doing it. It sounds like I or we might benefit from your experence and the how's and why's..... If for no other reason then to learn.
(side note: If you have a std camera shot the pictures and take it to the local walmart-kmart-walgreens and have some digital images done when you get your prints.)
I've attached a image of an x-y table for use on a drill press... from the price I don't think it is very current but when I get more time I might try and do something like this unless I come into more money...... or learn of a better way.
Ed
CMT Industrio Router Table System (orange cabinet) Ladd Table-mounted Routing 50 02-06-2008 12:34 PM
Questions about Table Saw fence tmiller Starting Off 4 04-02-2007 09:05 AM
Unrealistic Expectations? woodendigits Table-mounted Routing 35 01-23-2007 03:57 PM
Face Lift for the Router Fence bobj3 Jigs and Fixtures 7 06-05-2006 09:57 AM
Some Thoughts on Fence Control Gilbear Table-mounted Routing 5 12-20-2005 06:38 PM
