| | #1 |
| Registered User New Member | I need to recreate these air vents in a 3/4" piece of plywood, the hole is 3/8" wide and slightly rounded at the ends. What bit do i need, i was thinking a round nose bit but i dont think it will plunge deep enough to go all the way through the 3/4" wood. ![]() |
| | #2 |
| Senior Moderator Supreme Forum King | Chris, I would suggest a 3/8" spiral up cut bit. You can save a good amount of money by using a high speed steel bit for this. It should run you around $12. Remember to make your cut in a couple passes, perhaps a 1/4" at a time.
| | #3 |
| Registered User Dedicated Member | Use a 3/8 in straight bit but make about 4 passes taking a little at a time for a good sharp cut. Rick |
| | #4 |
| Registered User New Member | Thanks! |
