Thread Tools Display Modes
Old 04-07-2005, 09:07 PM   #1
archer_456
Jr. Member
archer_456's Avatar
archer_456 is on a distinguished road
Default Spiral bits?
I'm thinking about getting a set of spiral bits (1/4", 3/8", 1/2", 3/4") and have a few questions about them. What are the advantages or disadvantages between HSS and solid carbide? I always thought that carbide was always better, but I have also read that HSS does a smoother cut. Second question, how do you know when to use a upcut or a downcut spiral bit?
archer_456 is offline   Top - Reply with Quote
Old 04-07-2005, 11:27 PM   #2
jeff12002
Dedicated Member
jeff12002's Avatar
jeff12002 is on a distinguished road
Send a message via AIM to jeff12002
I prefer carbide to HSS for a few reasons. They stay sharper, longer. They stay sharper, longer, and they stay sharper longer. I have not experienced smoother cuts with HSS because I no longer own any. One thing I will tell you though about carbide spiral bits. They are generally solid carbide, not just the cutting surface, bit the shank and everything. Carbide is a very hard, very brittle substance. If you suffer from fumble fingers, be careful. If you drop them, they quite often break, or even worse, crack. The cracks are worse because they tend to go un noticed, and then break when you start to work, which damages your workpiece.
Down cut bits generally work well then you are doing through routing, (They throw the waste down, and away from the router, which keeps your view of the cutting path cleaner. Upcut bits are my favorites for sutting mortises. They produce a nice, smooth cut, and don't tend to clog up in tight spaces because the chips tend to lift up and out of the mortise as you cut.
If you are doing pattern work with a guide bushing, or bearing, remember that an upcut bit will leave a little bit of a fuzzy edge on the very top corner of the material, and the opposite for a down cut bit. This fuzz is easy to remove, but you may want to keep this in mind when you are choosing which side of the wood will be the finish side of the stock.
You won't be disappointed if you spend the money for these bits.
Good luck,
Jeff
jeff12002 is offline   Top - Reply with Quote
Old 04-08-2005, 01:29 AM   #3
cabinetsetc
Dedicated Member
cabinetsetc is on a distinguished road
Good luck,
Jeff
Jeff; It sounds like you know yout spiral bits. I've never used them or seen any for that matter. Of course I was never looking for any either. Are these bits just for strait cuts as opposed to a strait bit?
Learn something everyday.
Rick
cabinetsetc is offline   Top - Reply with Quote
Old 04-08-2005, 10:18 AM   #4
jerrymayfield
Forum Geek
Yes, they generally make a smoother cut. You can save some money by buying solid carbide end mills.
regards
jerry
Old 04-08-2005, 11:51 PM   #5
steveo
Forum Fanatic
steveo's Avatar
steveo is on a distinguished road
regards
jerry
Where do people get good buys on end mills?
Steveo
steveo is offline   Top - Reply with Quote
Old 04-09-2005, 10:31 AM   #6
jerrymayfield
Forum Geek
MSC industrial supply and several other industrial supplies. The hs steel mills will take a sharper edge but they don't hold the edge nearly as long.
regards
jerry
PS I have purchased many end mills from Enco.
Old 04-11-2005, 11:31 PM   #7
archer_456
Jr. Member
archer_456's Avatar
Good luck,
Jeff
Thanks Jeff, that makes a lot of sense. Looks like i will be better off gettling the carbide bits.
Cmt 1/4 spiral bits rich1 Table-mounted Routing 1 02-29-2008 03:02 PM
MLCS spiral bits rich1 General Routing 3 02-15-2008 09:09 PM
Spiral Bits RustyW Router Bits - Types and Usage 5 08-18-2007 11:47 AM
Spiral Bits fibertech General Routing 8 04-19-2006 12:06 PM
Spiral Bits ejant General Routing 4 02-09-2005 08:15 PM
