| | #1 |
| Registered User New Member | hi, i just purchased a porter cable 890 series routerwith the fixed base and plunge base. my question is with the plunge base. after adjusting the depth of cut, and tightening the depth rod locking knob, i made several cuts and realized the depth was changing. i found that the depth rod will slip if you push very hard down on the router. any one have any ideas or suggestions for this problem. thanks in advance |
| | #2 |
| Registered User Jr. Member | Good choice on the PC 890 series. Check the pole stop rod, make sure the knob on top of the verticle shaft is all the ways down. I found on my 895 that I had to tap the knob down all the way otherwise it would give variable depths of cut. Do not hammer to hard as it will surely break and then there's trouble. There is no need to have to push down hard when making the cuts, just guide the router and maintain control. Good luck with the router! Glenn |
| | #3 | |
| Retired Moderator Forum King | Quote:
Did you make sure to lock the plunge lock lever after plunging the router to the depth stop? Make sure it is locked after you plunge the router to the depth stop or depth stop turret. Last edited by -Sam-; 04-09-2005 at 09:51 PM. | |
| | #4 | |
| The Router Guys Forum King | Quote:
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. Last edited by BobandRick; 04-10-2005 at 12:49 PM. | |
| | #5 |
| Registered User New Member | removed the o-ring, problem fixed!! thanks alot, i bought this new router because i already own the self adjusting brand, thought maybe i now owned two. thanks again |
| Craftsman 17543 Combo Fixed Base Height Adjustment | Gator95 | General Routing | 14 | 11-29-2008 04:30 PM |
| **New** Router Workshop Series 500 DVD - Available Now!! | Mark | RouterForums.com News & Feedback | 9 | 08-05-2007 06:07 AM |
| Craftsman 315.175040 Router Depth Adjustment | gloftis | Starting Off | 3 | 06-16-2007 02:55 PM |
| Sloppy depth settings!! | Birch | General Routing | 4 | 04-06-2007 08:13 AM |
| Router Workshop series | Drick | Tools and Woodworking | 2 | 02-11-2005 08:37 PM |
