Help
IconIt appears you aren’t a registered member of the Router Forums community. Why not spend less than a minute and register for the oldest and largest router and woodworking community on the web! Join in over 29,500 discussions with over 65,000 woodworkers. If you’re an experienced or beginner woodworker, your questions and knowledge is always warmly welcomed by our community. Register now for your FREE account!
Router template inlay
This is a discussion on Router template inlay within the General Routing forums, part of the Routers category; Hi, Sorry, I'm not at all familiar with using a forum, but when in need! ...
Old 12-27-2008, 05:27 PM   #1 (permalink)
First Name: Victor
V Garry is on a distinguished road
Question Router template inlay
Report Post Report This Post!
Hi,
Got here by searching for a router inlay video. Started experimenting today with cutting an inlay with a bushing and template. Pretty much destroyed the inlay piece. Still using scrap wood. Not sure how to control the dimensional difference and depth from inlay to inset.
I'm using a Jasper plastic bow-tie template. Instruction says to cut inset using bushing and to cut inlay without the bushing. Question is, won't the bit cut up the template without the bushing?
I'm using a Triton router and Triton bushing set.
I welcome any direction.
Thanks,
V Garry
V Garry is offline
Sponsored Advertisement - Register now to remove this advertisement.
** Please be sure to read our Disclaimer at the bottom of the page. **
These advertisements are only displayed to guests, register now for your FREE account on the worlds largest router and woodworking community!
Old 12-27-2008, 05:32 PM   #2 (permalink)
xplorx4's Avatar
First Name: Jerry
xplorx4 is on a distinguished road
Welcome Garry, good to have on board. Someone will be around shortly that can help
your situation. I am kinda new myself and am just about routers and such.
Lamentations 3:22-23
xplorx4 is offline
Old 12-27-2008, 05:43 PM   #3 (permalink)
dovetail_65's Avatar
First Name: Dovetail
dovetail_65 will become famous soon enough
Originally Posted by V Garry View Post
Hi,
Thanks,
V Garry
NO, the bit will not tear up the template because the bushing is to snap off a template guide. The template guide the bushing comes off of keeps the bit from hitting the template.
You need two template guides or two patterns to make an inlay work. In short the snap off bushing acts as the larger size template guide and when taken off you use the template guide the bushing came off of as the second smaller template guide.
The inlay kit is just a way not to have to remove the template guide and put on the second template guide, saving time and hassle. The inlay kit just gives you a two in one template guide.
DO not confuse a bushing with a template guide. The bushing snaps on and off the template guide. I think you may be using a template guide and then no template guide which will not work:
Go here and read the instructions:
http://www.mlcswoodworking.com/shops.../TM24inlay.pdf
If you do not have the inlay kit with the snap on bushing you can use one template guide for the pocket and one template guide for the inset piece. Use the template guides on the chart posted by Bobj3 shown below, it works well:
The formula for using two differnt template guides is: the the recess(pocket) template guide size, minus twice the router bit diameter, equals the recess template guide size.
Some people do interchange the terms bushing and template guide, but it makes it confusing. To me a bushing snaps on and off something changing its size. A Template bushing snaps on or off a template guide. If a template guide is called a bushing its pretty difficult to explain the snap on bushing method for an inlay kit.
dovetail_65 is offline
Old 12-27-2008, 05:56 PM   #4 (permalink)
bobj3 has a brilliant futurebobj3 has a brilliant futurebobj3 has a brilliant futurebobj3 has a brilliant future
HI Garry
Inlays are fun to do with the router, many ways to do it,,
Here's a link or two you may want to read. see below
The real key is to have the RIGHT guides and the OFF set bushing...and to set the router up just right, the bit must be on dead center of the guides..
You may want to pickup one of the MilesCraft inlay kits ,it will have all you need,, check out the link below, posted by Bob
You don't want to drag your feet on this one, it will not last long..
http://www.routerforums.com/showthre...2001#post92001
http://www.youtube.com/watch?v=x1i6dUmi9xg
http://www.routerforums.com/introduc...post91676.html
http://www.routerforums.com/showthre...0767#post90767
http://www.routerforums.com/guide-bushings-templates/
Hi,
Thanks,
V Garry
MANY,MANY help files on John's web site
http://legacy.woodshopdemos.com/menu2.htm
Sommerfeld Tools ,Videos
Old 12-27-2008, 06:15 PM   #5 (permalink)
A newbie should not go for the Signcrafter. It could scare them away. I have both and its tough to use. Personally I consider it crap. Unless you are experienced and patient I do not recommend it.
The Design Inlay kit is different and I actually use one, but many others tend to have a love hate relationship with the thing. I like this one from Milescraft though.
Old 12-27-2008, 06:36 PM   #6 (permalink)
Hi Nick
The inlay kit from MilesCraft is one of the easiest ones to use almost no learning curve needed
It's so easy they just have a just a 1 1/2 min. video showing how to use it, that's easy ...plus it comes with bow ties templates
And because he has a Triton router that's a real pain to setup for the inlays..it should do the trick for him..
Just as a side note*** you will see a hold down board for the MilesCraft jigs I made one like it and I use the standard clamps and drilled out the pins on the slide bar so I can take them down and just pop them in the holes..works great for holding items down and it place...I use in on my WorkMate..
Old 12-27-2008, 06:42 PM   #7 (permalink)
Yes, I like the Design kit, but I do not like the Milescraft number and letter setup for the Signcrafter at all.
Sponsored Advertisements. Register to disable this advertisement.
Old 12-27-2008, 06:49 PM   #8 (permalink)
HI Nick
I said the same thing, then I rework the jig just a little bit now it's great..I see they now have a upgrade kit for it and they used one or two of my reworks
Tags
gvg
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Already Problems neuschu Introductions 11 12-15-2009 07:01 AM
skis for neophytes update - the verdict is in allthunbs Jigs and Fixtures 12 01-20-2009 09:38 AM
Inlay Chart/Update bobj3 Guide Bushings and Templates 3 12-19-2008 08:59 AM
