Thread Tools Display Modes
Old 04-19-2005, 11:02 AM   #1
Len Butler
Len Butler is on a distinguished road
How does one route a circle or arch shape using the router?
Len Butler is offline   Top - Reply with Quote
Old 04-19-2005, 01:17 PM   #2
Dan Thompson
New Member
Dan Thompson is on a distinguished road
Try this web site. I have not used this site or made circles yet.
http://us.oak-park.com/catalogue.html?list=JIGS--
HTH
Dan Thompson is offline   Top - Reply with Quote
Old 04-19-2005, 03:26 PM   #3
cabinetsetc
Dedicated Member
cabinetsetc is on a distinguished road
I have jigs set up in the shop but in the field when little else is available, I use a piece of baling wire . Put a screw in the centre of your circle area and the other end of the wire to the router base. If you don't want to mark the surface there are suction cup set ups you can buy at most router shops. Good luck.
cabinetsetc is offline   Top - Reply with Quote
Old 04-19-2005, 05:36 PM   #4
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi Len:
you would use a circle jig attached to your routerto cut circles. Usually the jig is an extended base plae that you can screw on to the router in place of the regular base plate. By attaching the end of the base to the center of your material and simply run the router around after adjusting the jig to the diameter of the circle you may need.
If an arc is part of a circle you can use the same jig for an arch. If the arch is not a true arc, you can cut a pattern to follow with the router..
hope this helps. Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
New Router my way reible General Routing 14 06-10-2006 11:19 PM
