| | #11 |
| Registered User New Member | I see all of these good recommendations of circle cutting jigs for portable routers, but, can anyone recommend jigs for router tables? I need to make a number of uniformly-sized wheels that have been roughly sized (witha circle cutting jig) on a bandsaw and thought a similar setup would apply to a router table. Would need to know which direction the blank should rotate; location of where the bit should be cutting into the blank; angle of the jig relative to the bit. |
| | #12 |
| Registered User Sr. Member | If you need to make a bunch of the same size, you could make a template out if thin 1/4" material- using any of the jigs listed above (mine is a simple piece of scrap 1/2" thick plywood 6"x24" with a carriage bolt in one end and the router mounted to the other- The carriage bolt goes through the middle of the circle and I adjust the diameter by moving the carriage bolt closer or father away from the router). once you have your template, rough cut all your circles with band/jig saw keeping 1/16 to 1/8 wide of the desired circle, mount the template to it with double sided tape (you need less than you think- very sticky stuff) and use a flush trim bearing guided bit and you'll have identical, perfect circles every time without having to drill a hole in the middle. It's a bit of a process, but if you need a bunch, once the template is set it's smooth sailing... plus it's nice not putting a hole in the middle... Last edited by rprice54; 01-11-2006 at 08:45 PM. |
| circular edge shaping on a router table | ed Gauci | Introductions | 9 | 03-21-2008 08:13 PM |
| Circular guide-- | asrubin | Portable Routing | 1 | 01-06-2008 05:30 PM |
| Base plate for circular saw? | Birch | Tools and Woodworking | 5 | 05-31-2007 04:58 PM |
| Circular porch jig | TRosell14843 | Jigs and Fixtures | 1 | 10-24-2006 05:31 PM |
| Circular Saw | -Sam- | Tools and Woodworking | 12 | 04-13-2005 11:40 AM |
