Thread Tools Display Modes
Old 05-05-2005, 03:57 PM   #1
mstevensjr
mstevensjr is on a distinguished road
Default Plastic router fencing material
On The Router Workshop they use plastic fences. Can anyone give me a good cheap source for that material?
Melvin
mstevensjr is offline   Top - Reply with Quote
Old 05-05-2005, 04:49 PM   #2
Bob
Forum Moderator
Supreme Forum King
Bob's Avatar
Bob has a spectacular aura aboutBob has a spectacular aura about
I purchased mine from our sponser at this link.
http://us.oak-park.com/catalogue.htm...-&product=F016
Cheers
Cheers,
Bob
Bob is online now   Top - Reply with Quote
Old 05-05-2005, 05:42 PM   #3
Mark
Forum Administrator
Supreme Forum King
Mark's Avatar
First Name: Mark
Mark is an unknown quantity at this point
Melvin
The material used is called, Polyethylene. I'm not quite sure of where they purchase the material, but considering you want a small quanity its probably going to be quite expensive.
If you would like some more information, I would suggest that you pay http://www.google.com a visit and input "Polyethylene" as your search query.
Mark,
Administrator and Technician of RouterForums.com
RouterWorkshop.net - Get more out of your router!
Mark is offline   Top - Reply with Quote
Old 05-05-2005, 08:53 PM   #4
ChevyNomad
Jr. Member
ChevyNomad is on a distinguished road
It's UHMW Polyethylene - that's Ultra High Molecular Weight Polyethylene.
The best place I've found to get it is from McMaster Carr http://www.mcmaster.com/
At the top of their page go to catalog page 3333 for bars. 1" x 2 1/2" is $6.75 per foot.
Hopes this helps or at least gives you some pricing references.
RL
ChevyNomad is offline   Top - Reply with Quote
Old 08-29-2005, 08:02 PM   #5
ikovnick
ikovnick is on a distinguished road
I need the fence 32"
ikovnick is offline   Top - Reply with Quote
Old 08-30-2005, 12:18 AM   #6
Pop_pop1
Forum Fanatic
Pop_pop1 is on a distinguished road
I get the UHMV Polyethylene & HD Polyethylene I use from MSC Industrial Supply Co. Their web site is WWW1.mscdirect.com . They have a very large inventory and a 4" thick catalog to go with it. The HDPE is a little cheaper than the UHMW. If you buy a sheet of it and cut it to the size you want it is a lot cheaper than buying a pre cut piece from a WW supply. You'll have some left over for jigs and fixtures.
If you want some smaller pieces, Woodcraft Supply sells random pieces by 3lb & 4lb lots. It is good stuff, and a mix of colors too. Hope this helps......Chuck
PopPop
If it's worth building, It's worth building well.
poppop@routerforums.com
Pop_pop1 is offline   Top - Reply with Quote
Old 09-02-2005, 04:28 PM   #7
deacon
New Member
deacon is on a distinguished road
Hi
For what its worth I make mine out of oak that I by in the lumber yard. Lowes stock it in 2, 3 and 4 ft lengths it is smooth and all you need to do is cut your hole for the bit just make sure that you get pieces that are streight. I use a 1x3 and a 1x2 I screw and glue the 1x2 to the 1x3 after I cut my holes using a drill press and hole saw and then I attach a 2 inch piece of pvc to the fence to except my shop vac hose keeps the table clean except when cutting datos. I finish mine with a coat of poly and they look great. I made 2 for my table one to fit across table and one for the length in case I am working on some long pieces. The upright piece also gives you a little more support on tall pieces. Any way we all have things that work best for us it may not be right for you just a thought about an alternet way of doing things.
Deacon
deacon is offline   Top - Reply with Quote
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
What Router to buy (cutting plastic) stevegriswold General Routing 1 07-03-2005 01:56 PM
