| | #1 |
| Registered User New Member | Hi, all. Occasional lurker, first time poster here. I'm interested in hearing from folks who are actually own and use the vacu-plate and manifold...or who have owned it but don't use it any more. How well does it collect dust compared to other DC methods you've used for the router table? Do any of you find that you still need to use an above-the-table vacuum inlet in addition to the vacu-plate? Thanks in advance. Regards, John |
| | #2 |
| Retired Moderator Forum King | Hey John, Yes, I have the vacu-plate system and it is worth getting in my opinion. I connect my shop vac to it and wow, it picks up a whole lot of the woodchips. I think it's one of the best systems out there. I don't use any other dust collecting system anymore like I use to when I didn't have the system. But you might have to if you are going to do some pattern routing and need some kind of set up. Cheers! ![]() |
| | #3 |
| Registered User New Member | Gracias, Boricua. Back to lurkin' for me. Regards, John |
| | #4 |
| Registered User New Member | Yes, I used the vacu-plate but found that it had limited value so I had to remove it and now use other DC methods. It works OK with small bits but a good shopvac works just as good. Dave |
| | #5 |
| Registered User Dedicated Member | I have the vacu-plate as well. I just bought a shop-vac (QSP 13 gal. 4.5hp)....... The vacu-plate is 2 1/4" in dia.' but I just measured the hose, and it's larger than the vacu-plate opening. I have the pamphlet that came with the shop-vac, and all the fittings etc are 2 1/2". How do I hook it up then? There is a 90 degree elbow, but it doesn't show the dia. I don't want run the hose directly to the vacu-plate (since I would have to add the screw to the hose;to twist it into the plate). Maybe I'll go look at Canadian Tire to see if they have an elbow (2 1/4") I could "permanently" attach to the vacu-plate to and run the hose from the elbow.......
__________________ I am Kenadian! |
| | #6 | |
| Registered User Dedicated Member | Quote:
VACU-PLATE SHMACU-PLATE, "I MADE MY OWN" AND IT WORKS LIKE A CHAMP!! | |
| Insert Plate size and 11.5" handle spread; how to prevent problems | Ladd | Table-mounted Routing | 34 | 12-14-2007 02:08 PM |
| Marvel 40 Router Plate | cbsjoez1935 | General Routing | 0 | 10-08-2007 02:11 PM |
| choosing a base plate ... | reikimaster | Table-mounted Routing | 5 | 01-13-2006 11:37 PM |
| Centering Base Plate | -Sam- | General Routing | 15 | 01-04-2005 11:15 AM |
| Vacu Plate | ejant | Table-mounted Routing | 0 | 11-06-2004 11:56 AM |
