| | #11 |
| Registered User Member | They Posted!, and I'd say that's what it is all about......... Cheers! |
| | #12 |
| Registered User Member | What I need to know is how to make the shoes? I'm not the sharpest pencil in the box and I can't make hide nor hair of the plans I got with the Push Stick Handle.
__________________ Bob from Northwest Florida |
| | #13 | |
| Forum Contributer Supreme Forum King | Hi Bob Pop in your 1/2' DOVETAIL bit in the router table, set the bit height to 3/8" above the router table top then move the fence over so the bit is in the center of the stock you are going to use for the shoe, lock the fence in place then get your push block and push the stock over the bit keeping it to the fence and holding it down to the table top... Cut you stock just a bit longer than you need just in case you get rip out on the end of the pass...if so just trim off the end for a nice clean dovetail socket.. ![]() Then test fit the pin in the socket, it should just slide in free without the need for a hammer...you may need to adjust the bit up or down to get it to fit just right once you have it set right , make some backups they do get nailed now and then.. ========= Quote:
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 05-08-2008 at 12:42 PM. | |
| | #14 | |
| Registered User Member | Quote:
__________________ Bob from Northwest Florida | |
| | #15 |
| Registered User Forum Fanatic | Bob, from Northwest Florida, Take the advice, which BobJ gave you, and do the same on the other side (top or bottom) of the push block piece. I would not make the dovetail slot go all the way through on either side. That way the handle has a stop point and the side support, you mentioned, has the same. In addition, cut a tight dovetail slot across the back of the block and that will be your "bottom pusher", while the long piece down the middle, or so, will be your side support. Hope this helps. Joe Z.
__________________ JoeZ If you never made a mistake, you never tried anything
| | #16 |
| Forum Contributer Supreme Forum King | Hi Bob Joe is right but I should have said once you have the slot just right make a dovetail key to slide in the slot and then glue it in place for a spot point for the handle,,,many have a hard time backing up the shoe with the bit spining and it takes time to do it just right without making the dovetail slot bigger than it should be...I would also suggest using a 1/4" or 5/16" strait bit 1st to remove some of the stock from the dovetail slot, it makes it easyer for the dovetail bit to work...and a place for the chips inside the dovetail slot.When moving the dovetail bit back up, it's likes to jam and pull away from the fence and once it jams it's a real trick to get it out of the slot, not to say anything about it's a good way to cook a good dovetail bit.. ![]() May I also suggest you make a shoe like the one below, you will be surprise how well this type of push stick/block works for many router jobs with some double sided carpet tape on the front side of the push block it will hold the stock in place and will take the place of many coping sleds.=========
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 05-08-2008 at 05:42 PM. |
| | #17 |
| Registered User Supreme Forum King | Awwww, the wonderful thing about push sticks.... one can make them any size, shape or form in which suits the operator. ![]() Bob, last time I snuck a peek into your shop, I didn't see such a push stick.... so, where ya been hiding it?! LOL ![]()
__________________ Ken (On temporary leave of abscense) "A VETERAN" "Wether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown |
| | #18 | |
| Forum Contributer Supreme Forum King | Hi Ken hahahahaha I have so many push sticks I have lost count ![]() It's one of the things I make all the time trying to find one that works for all router jobs I have one of the new yellow ones but I'm not to impress with it. Home/Shop made ones work the best for me.. ![]() ============= Quote:
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ | |
| | #19 |
| Registered User Member | Thanks to all you guys. I think I have the concept down now.
| | #20 |
| Registered User Supreme Forum King | Hi BJ, Being a little bit on the lazy side at the moment... I have 3 OP's handles. I've made a few different "push blocks" for them. Fortunetly, they work for me, and are comfortable to use. When I made my version of your push block, I copied the shape and form from OP's handle. Granted, it's only 3/8" thick but, again it works, sometimes I do wish they were thicker more like 3/4" but, that's why we make them. ![]()
| Deluxe Push Block | bobj3 | Jigs and Fixtures | 56 | 03-29-2008 09:00 AM |
| Rounding off the ends of a stick | tpyke | Table-mounted Routing | 5 | 03-03-2008 04:14 PM |
| Push stick handles | S Bolton | Jigs and Fixtures | 3 | 11-26-2007 06:20 PM |
| Push Stick Handle | garryjc | Jigs and Fixtures | 4 | 10-04-2007 08:38 AM |
| Modified Bj's push block | Bob | Jigs and Fixtures | 5 | 06-03-2007 09:13 PM |
