The Network:
 Recommended Stores:
RouterForums.com - Your Online Router and WoodWorking Community
Login
RouterForums.com Search:
    Advanced Search
FAQ
Reload this Page I want Ricks push stick!!
General Routing Discuss I want Ricks push stick!! in the Routers forums; Hi Ken That sounds like it would work great I'm a cheap SOB and I don't have any ...
New Reply | Quick Reply
Thread Tools Search this Thread Display Modes
Old 05-09-2008, 07:33 PM   #21
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
User Info
Trader Rating: (1)
Gallery: View
Country: USA
Send Private Message | View Profile
Hi Ken
I'm a cheap SOB and I don't have any OP push handles but along time ago I got a B & D push stick and have used it for may handles for jigs ,,,
I didn't care for the B & D push stick because it is/was so thin but I do use it from time to time to rip thin stock on the table saw but I now have a new jig to do that and it's alot easyer and a bit more safe than traping the stock ,I can now rip 1/8" and 1/4" banding that comes out right on the button
But back to the Push handle I used the B & D for a template pattern and some MDF stock to give it more mass and to fit my hand, they come out to 1 1/4" wide, that helps with my big hands and just the right size for me...I have one or two with the dovetail key on them but I do like to glue and screw them in place...
Here's a snapshot or two of the B & D one I use for the patterns ,I just stick them on the stock and use the trim bit to make new ones...
i-want-ricks-push-stick-0165.jpg  i-want-ricks-push-stick-0166.jpg  i-want-ricks-push-stick-0167.jpg
Always keep a open mind but not so
far as to let yours brains fall out.
RW Router Tip Archive
www.routerworkshop.com/router_tip_glossary.html
FREE PLANS
from soup to nuts,tons of free plans.
www.absolutelyfreeplans.com/
Bj
bobj3 is offline   Top | Reply with Quote |
Sponsors
You currently aren't registered, click here to register.
Old 05-09-2008, 11:18 PM   #22
mftha
Dedicated Member
User Info
Trader Rating: (0)
Gallery: View
mftha is on a distinguished road
While this post may be a bit off point, Please indulge me as I strongly reinforce the necessity for using safety devices while routering. I was not very active on this forum for several months because I did not use a push stick when I should have. I also made another unthinking mistake that had I been using a push stick would have had been much less consequential. I was attempting to make a template with a groove wider than any of the straight bits in my collection. I made the first cut, then turned it around and started the second cut. As it was I realized the second cut was a climb cut. The piece shot away and my left forefinger made contact with the spinning router bit. It cut away the top layer of skin and bled profusely. Had I been using a push stick it might have been destroyed but my finger would have not been injured. After over a month of daily rinsing with hydrogen peroxide and bandaging with neomycin and bandaging so as to immobilize the end joint, my finger returned to almost normal, but now it is stiffer and I have less range of mobility in the end joint. The joint itself was not damaged, thanfully. The finger injury may have led to overuse of my right arm (I am confined to a wheelchair) to compensate for my left arm, and now in spite of some very effective physical therapy, I may need one or even two shoulder replacements; I now compensate for the right shoulder by over-using the left arm. (Actually there was already some deterioration of my right shoulder at the time, but my few seconds of not thinking has long lasting consequences.)
mftha is offline   Top | Reply with Quote |
Old 05-09-2008, 11:34 PM   #23
karateed
Forum Geek
karateed's Avatar
User Info
Trader Rating: (0)
Gallery: View
Country: Squamish, BC, Canada
karateed is on a distinguished road
Hi Mftha,
Not off topic at all....first and foremost is safety and that's exactly what push sticks are about. Thank you very much for sharing you story as it may help some realize the importance of a few moments of making this tool for safety.
I'm really sorry to hear you had to and are suffering from your accident. I hope down the road you have as full a recovery as possible.
Again, thank you for sharing, it just might be someone else will not suffer the same fate because of your courage to come forward with your story.
Ed......:-)
karateed is offline   Top | Reply with Quote |
Old 05-09-2008, 11:47 PM   #24
mftha
Dedicated Member
User Info
Trader Rating: (0)
Gallery: View
Thanks very much Ed,
Sharing our experiences and learning from them is what this forum is all about!
I have largely recovered used of my left forefinger, but the whole episode may have simply accelerated the inevitable. My shoulders were wearing out because I work in an environment that is almost wheelchair-hostile, with supervisors who keep things just this side of justification of discrimination lawsuits.
In the meantime I look at what I can do and try to figure out ways to do more easily those things that are difficult for me.
Old 05-11-2008, 09:51 PM   #25
mftha
Dedicated Member
User Info
Trader Rating: (0)
Gallery: View
Birchwood,
which push stick do you mean? the one with the saw-like-handle or the one that Rick called a Shaker or Quaker or some such name; on with a simple round veritcal handle? Have you looked at the safety sets sold by Rockler, MLCS and other places? They have nice collections.
Search this Thread:
Advanced Search
Bob and Ricks Work Shop pmspirito Portable Routing 35 07-03-2006 06:58 AM
Bob and Rick's Router Bob N Table-mounted Routing 5 06-27-2006 03:32 PM
Push or Pull the router template tom Portable Routing 27 07-21-2005 05:58 AM
double stick tape trap Tools and Woodworking 7 02-17-2005 01:59 PM
Powered by: vBulletin Version 3.0.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd. - Copyright 2007 RouterForums.com - Search Engine Optimization by vBSEO 3.0.0
Professional Web Hosting provided by: RosenMill Technologies
