Thread Tools Display Modes
Old 09-18-2004, 07:58 PM   #1
NewMontanaWorkshop
Forum Geek
NewMontanaWorkshop's Avatar
NewMontanaWorkshop will become famous soon enough
Default PC 690 Plunge Base problem.
I picked up a new (used) router yesterday. Was out looking for hand planes, but couldn't pass up the deal on this one.
It does have a problem though, the plunge action sticks something terrible. The downward motion works reasonably well, but does seem to catch just a bit. Releasing the plunge lock though -- there is about a 5% chance that the plunge will rise to the top of the base. I have to push downwards again (numerous times) and finally it will manage to push the base all the way out.
I'm going to tear it down tomorrow and see if I can find anything obvious, but thought I'd ask here if anyone has anything specific for me to look for.
TIA
NewMontanaWorkshop is offline   Top - Reply with Quote
Old 09-18-2004, 08:04 PM   #2
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
Sounds like the router needs a good cleaning.
Rick and Bob
The Router Guys
Old 09-18-2004, 08:29 PM   #3
ejant
Router King
Supreme Forum King
ejant's Avatar
ejant will become famous soon enough
Disassemble the router to get to the slide tubes. Clean them with very fine steel wool or scotchbrite and reassemble.
Do not lube the tubes as this will cause them to collect dust and stick again.
ejant is offline   Top - Reply with Quote
Old 09-18-2004, 08:34 PM   #4
NewMontanaWorkshop
Forum Geek
Thanks for the cleaning notes. That will get taken care of tomorrow.
I did find one small note relating to the lock nut at the bottom of the stop screw, and that the stop screw should not extend beyond the lock nut or be tight against the base housing as it will cause binding.
Old 09-18-2004, 10:34 PM   #5
reible
Supreme Forum King
reible's Avatar
Hi,
I have a 690 with the plunge base and have never had the problem you describe. I use it as a hand router and it has never been upside-down in a table. If it was used in a table then the dust issue could still be the problem.
I do have 3 1/2 HP Sears router in my table and it gets dust in it from being inverted and it has similar problems and needs to be cleaned out. For a while it was like every other month until I plugged up the tube holes with corks now it is about one a year. Taking the springs out sure made it nicer to use. Thanks Router Workshop!
BTW (by the way) a coat of paste wax works wonders on slides, tabletops, etc. I try to get carnauba and put on a couple of coats. Things slide and don’t rust when waxed.
Ed
Old 09-20-2004, 06:15 PM   #6
reible
Supreme Forum King
reible's Avatar
So Snowshoe what did you find the problem to be?
Ed
Old 09-20-2004, 07:02 PM   #7
NewMontanaWorkshop
Forum Geek
Ended up having to help my sister get her new laptop setup, so that involved having dinner and visiting with some friends of theirs from Iowa.
Took up most of the day and I never got out to the shed to look at it, maybe tonight or tomrrow.
Old 09-21-2004, 03:10 PM   #8
NewMontanaWorkshop
Forum Geek
Ed
Cleaning up the spring tubes was the ticket.
Works smooth as silk now.
Thanks.
Old 09-21-2004, 03:34 PM   #9
reible
Supreme Forum King
reible's Avatar
Thanks.
That's what we like to here!
Ed
Old 09-22-2004, 12:47 AM   #10
NewMontanaWorkshop
Forum Geek
Now to order the couple of parts that were missing (pointer and knob for the depth rod) and I'm all set. Pieced together a 693PK kit from ebay and local pawn shops.
Colt plunge base bobj3 Jigs and Fixtures 19 04-01-2008 08:54 PM
Bosch 1617 router base problem bill kay General Routing 4 01-09-2008 12:53 PM
Flat side of base plunge base Noddy General Routing 2 09-11-2007 11:30 AM
Pitting in PC plunge base DONALD Tools and Woodworking 5 12-04-2004 11:36 PM
Converting fixed base to plunge base. -Sam- Portable Routing 4 09-30-2004 04:53 PM
