Thread Tools Display Modes
Old 08-07-2005, 10:26 PM   #1
reds_21
Forum Fanatic
reds_21's Avatar
reds_21 is on a distinguished road
Default rabbet router bits
ok, new topic!!!!
i am attempting a project that requires a rabbet joint at the ends. now i have purchased the router bit from rockler and now have questions on how to apply the rabbet cut.
is it easier to do this cut on a mat or easier using a router table since the bit cutter is on the side compared to the cutters being at the bottom of the bit like a straight bit.
again, in desperate need of help!!!
shawn
reds_21 is offline   Top - Reply with Quote
Old 08-07-2005, 10:29 PM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
The rabbet bit should have a bearing to guide you along the edge of your wood. All you should need is the proper depth adjustment and to clamp your wood down so it doesn't move.
Old 08-07-2005, 10:34 PM   #3
reds_21
Forum Fanatic
reds_21's Avatar
ok, so it doesn't matter weather it is done on a pad or a table?
i think i can do that just need to get the screws replaced on the table then!!
Old 08-08-2005, 12:45 AM   #4
reible
Supreme Forum King
reible's Avatar
Originally Posted by reds_21
ok, new topic!!!!
shawn
If you have the router table I would use that. If you can, using a fence is a good idea...
I never trusted those mats but I know some people use them..... One issue if you do use the mat make sure that the bearing (or screw holding the bearing) of the bit is not so low as to hits the mat or what is under the work piece.
Ed
Old 08-08-2005, 07:00 PM   #5
Learning Herb
Forum Fanatic
Learning Herb's Avatar
Learning Herb is on a distinguished road
Good ans. Ed. I have seen thoese mats get stuck in the bit and it will defitinly wake you up..I my self would use the table it is so much easer and safer than a hand held job. Learning herb
I try to learn some thing new each and every day ,
Learning Herb
Learning Herb is offline   Top - Reply with Quote
Already Problems neuschu Introductions 7 01-22-2008 11:32 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
New Router my way reible General Routing 14 06-10-2006 11:19 PM
