| | #1 |
| Marine Engineer Forum King | Having multiple routers makes life easier, but sometimes it can get confusing with all the cords laying around. To make sure I have the right plug for the right router I have stuck a neon cable tie at each end of the router cable. Different colors on different routers make it easy to tell if the correct router is plugged in, or more importantly unpluged when changing bits. I had used colored electrical tape before, but the cable ties work a lot better. Safety first!
| | #2 | |
| The Router Guys Forum King | Quote:
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. | |
| | #3 |
| Marine Engineer Forum King | Please feel free to share my tip with everyone
| | #4 |
| Registered User Supreme Forum King | When I don't have a bit in my table mounted router I put a black plastic 35mm film canister over the collet. This keeps debris out and this beats having to un-mount the router to turn it over to clean it. Another reason the tabletop system used on the Router Workshop is so nice, out and over in seconds. Ed |
| | #5 |
| Registered User Supreme Forum King | This really happen to me 4 or 5 years ago: I was ripping a board and the power went off. It is pitch black and the first thing I think of is getting to a flashlight hanging about a half a shop away. As I’m making my way to the flashlight the power comes back on…. So does the saw with a board still in contact with the blade. I was lucky that day. If this happens to you remember to get the power tool turned off FIRST! I learned my lesson the scary way maybe so you don’t have to. Ed |
| | #6 | |
| Forum Administrator Supreme Forum King | Quote:
__________________ Mark, Administrator and Technician of RouterForums.com Contact RouterForums.com Refer a friend to RouterForums.com! | |
| | #7 |
| Registered User Forum Fanatic | That's unlikely to happen here reible All router tables, table saws and many other tools are fitted with a no voltage release switch. If the power goes off it stays off regardless of the main coming back on. The switch has to be turned on again as the loss of power makes the switch need resetting. Even the cheapest bench tools have this switch, for safety.
__________________ Dewy support team at Paltalk voice chat program |
| | #8 |
| Router King Supreme Forum King | In a table mounted router and a bit is chucked up and the router not in use cover the bit or lower the bit below table height. Same thing with a table saw, lower the blade when not in use. |
| | #9 | |
Ed Last edited by reible; 09-20-2004 at 07:37 PM. | |
| | #10 | |
This would make an interesting survey, I personal never leave a bit in a router, either the table mounted or handheld. I never leave a drill bit in the chuck or the key in the chuck either. How about others? Ed | |
| Quick and Easy Turning Project.... | challagan | Corey's Wooden Stuff | 10 | 04-14-2008 04:36 PM |
| Quick change router mount? | archangel | Table-mounted Routing | 12 | 01-17-2008 01:51 PM |
| Raised Panels Quick and Easy | bobj3 | Jigs and Fixtures | 2 | 06-03-2006 12:56 PM |
| Bit Quick Connects | BAMILLER | General Routing | 3 | 12-06-2005 09:44 AM |
| **New Function** Quick Thread | Mark | Lobby | 1 | 11-27-2005 09:25 PM |
