Help
IconIt appears you aren’t a registered member of the Router Forums community. Why not spend less than a minute and register for the largest router and woodworking community on the web! Join in over 20,000 discussions with over 40,000 woodworkers. If you’re an experienced or beginner woodworker, your questions and knowledge is always warmly welcomed by our community. Register now for your FREE account!
Removing springs from a Bosch 1617EVSPK
This is a discussion on Removing springs from a Bosch 1617EVSPK within the General Routing forums, part of the Routers category; I found some posts about removing springs, but couldn't find anything about removing springs specifically ...
Old 05-07-2009, 01:12 PM   #1 (permalink)
sher622's Avatar
First Name: Jeff
sher622 is on a distinguished road
Default Removing springs from a Bosch 1617EVSPK
Report Post Report This Post!
I found some posts about removing springs, but couldn't find anything about removing springs specifically from my Bosch. I am making a table now and the top is finished and temporarily mounted to help build the cabinet. After only making a few cuts, I realize that I HAVE to remove the springs to keep my sanity and keep from using more scrap in test cuts than my project, HELP!!
sher622 is offline
Old 05-07-2009, 01:25 PM   #2 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi Jeff
Here's one, they don't list the Bosch but most are just about the same on many routers, it may help
Router Workshop: Spring Removal
With luck Mike will see your Post, I think he as remove his spring from his Bosch..for his OP table setup..you can always PM him or send a email and get some help from him..
Router Forums - View Profile: Mike
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
How to Remove and Reinstall a Drill Press Chuck
See all 48 videos, Great tips.
http://www.youtube.com/watch?v=KbI_7...=31&playnext=3
HOW TO Inset a Router Base Plate
http://www.popularwoodworking.com/ar...e_plate_video/
Wood Working Videos, many great ones.
http://web.me.com/deceiver6/Deceiver/wwvideos.html
Router Tables
Router Tables Made Easy, with this video.
http://www.sommerfeldtools.com/Route...ductinfo/DVD3/
http://www.youtube.com/watch?v=sFW5gBYwt4M
http://www.youtube.com/watch?v=QjW5H...eature=channel
Old 05-07-2009, 02:24 PM   #3 (permalink)
levon's Avatar
Location: one of a very select few born , not transplanted into Georgia, USA
First Name: levon
levon is on a distinguished road
forgive me if im off base, but doesnt the 1617 evspk come with a fixed base that could be mounted to the table and leave the plunge for freehand work? im just asking?
levon
levon is offline
Sponsored Advertisements. Register to disable this advertisement.
Old 05-07-2009, 05:06 PM   #4 (permalink)
xplorx4's Avatar
First Name: Jerry
xplorx4 is on a distinguished road
I thought the same thing Levon, why not use the fixed base for the table, just a thought!!
Lamentations 3:22-23
xplorx4 is offline
Old 05-07-2009, 11:02 PM   #5 (permalink)
sher622's Avatar
First Name: Jeff
Levon, yes it does have a fixed base. And I have a knob for the micro adjust, but I was thinking it would be tougher on bit changes and times that require moving the height more than a half an inch or so. I was really using the plunge base as a temporary solution anyway. I just built the top and have it temporarily mounted while I build the cabinet. I was planning on making or buying a lift. I think I came up with a good design to build a lift that can be raised with a screw for micro adjustments and also a quick release for bit changes. I'll post some pics if I get it working.
I digress... I suppose I'll try the fixed base and see how I like it. I've been making some rail and stile panels and the adjustments are really difficult to get perfect, even using the micro adjust on the plunge base.
sher622 is offline
10% OFF at Rockler.com!
Old 05-08-2009, 03:21 AM   #6 (permalink)
Mike will become famous soon enough
Jeff, mounting the fixed base is the way to go. Remove the wooden knobs and you get more room and easier adjustments. The 1617 has 3 rough adjustments to get you close then the adjuster takes over. You will find you do not need a lift. It is easier to pop the mounting plate out of the table, change your bit, make the height adjustment and drop it back into place. I guarantee this is faster than any lift on the market. (And you get to spend all that money you save on bits!)
Old 05-17-2009, 04:34 PM   #7 (permalink)
sher622's Avatar
First Name: Jeff
Default Final setup
Thanks to all for recommending the fixed base and insisting it is the best way to go. My biggest hangup was that I couldn't do fine adjustments from above the table. I really didn't want to have to move the fence, only to have to reset it. Well, here's what I finally ended up with.
The materials I bought were:
3/16 hex drive threaded screw (didn't really care what the length or size/threads are) Actually I bought a short one to keep the possibility of the screw getting knocked off.
3/16 hex wrench
total cost was about $3
Photo 1 and 2: So I used a 5/16 drill bit and drilled out the hole that happened to already be started in the base directly above(with the base upside down) the fine adjustment screw.
Photo 3: I used a bit of J.B. Weld to attach the threaded screw to the bottom side of the fine adjustment screw with the Hex opening toward the base. I got it centered as good as I could, but lets realize that it really isn't imperative that this be exactly centered to the thousanth of an inch.
After drying overnight, I drilled the new holes in the base to mount the fixed base. Then using the same 5/16" bit, I drilled a hole to match the one in the base for the wrench to fit through. You can barely see the hole in the top in photo 4.
Photo 5: Now, to use it, I still have to get under the table, which I can do from the front to unlock the cam-lock, then each turn of the wrench is 1/16" from above the table. When the adjustment is done, lock the base and I'm off.
I forgot to mention, I did take off the wooden knobs.
I'm still finishing the cabinet to the router table, so I'll post those photos later.
Name:	Fixed Base Lift (7).JPG
ID:	24064  Click image for larger version
Name:	Fixed Base Lift (9).JPG
ID:	24065  Click image for larger version
Name:	Fixed Base Lift (10).JPG
ID:	24066  Click image for larger version
Name:	Fixed Base Lift (11).JPG
ID:	24067  Click image for larger version
Name:	Fixed Base Lift (6).JPG
sher622 is offline
Shop now at Tool King!
Old 05-17-2009, 09:39 PM   #8 (permalink)
rolanddds is on a distinguished road
Mike... Do you use the OP set up as Bob thought? But your using a fixed base and not a plunge attahed to the insert, right? If you were using the plunge, then I assume you would remove the springs?
Tom
rolanddds is offline
Old 05-17-2009, 10:45 PM   #9 (permalink)
First Name: Lance
westend is on a distinguished road
Nice, creative solution, Jeff. Don't let Bosch in on that, though. They make an above table, adjustable fixed base, the RA1165.
Actually, all new 1617EVS PK kits come with the above table adjustable base. I use this same base in my table and it works out well. Looking forward to the pics of your finished table.
Sawdust is not dirt
westend is offline
Shop now at Rockler.com!
Old 05-17-2009, 10:49 PM   #10 (permalink)
sher622's Avatar
First Name: Jeff
I saw that on some demo or a show where they adjusted that base through the plate. I bought my router about 3 years ago, and I don't think that base existed at the time.
sher622 is offline
Tags
bosch 1617, springs
Bosch 1617EVSPK or Bosch 1619EVS LBrandt Table-mounted Routing 24 01-25-2010 03:28 PM
Bosch 1617EVSPK Router -Sam- General Routing 49 07-22-2009 11:07 PM
Mouting Bosch 1617EVSPK to Skil 570 router table calmoy Table-mounted Routing 4 05-17-2005 07:27 AM
My New Bosch Router Bosch 1617EVSPK Review GoonMan General Routing 2 04-02-2005 05:25 PM
To those who bought the Bosch 1617EVSPK -Sam- General Routing 4 03-26-2005 11:51 PM
