| | #41 |
| Registered User New Member | hi terry, i have downloaded skype and installed, but how can i used that programm thanks albert |
| | #42 |
| Registered User Dedicated Member | Terry, awesome job! The signs look great, thank you for sharing the pics with us. Paul ![]() |
| | #43 |
| Registered User Forum Geek | Great,, ALbert,,,, I will get with Glennmore and see how to get ahold of ya,,, hahaha,, I am hardly the computer expert here,, so now I will now go to the big Kahona on talk ,,,,, I will get back with ya,,,
__________________ Terry It seems like every where I go,,,,,,,,,,,,,,,,,,,,,,,,, there I am... |
| | #44 |
| Registered User Forum Geek | Thanks Paul,,, they are a ton of fun to make and easy to do,,, sure gets you a lot of notice when ya get one done,,, Give her a shot, and show us what ya come up with.
| | #45 |
| Forum Moderator Supreme Forum King | Paul pm Terry with your your skype name and he can look it up and add you to his contacts. Then he will be able to call you and talk to you. And if you add skype to your profile here all that have skype can get into contact with you. Hope this helps you out.
__________________ Glenmore Days without wood working are days not worth getting up for. Last edited by Glenmore; 09-03-2008 at 03:09 PM. |
| | #46 |
| Registered User Jr. Member | thanks for the input everyone i appreciate it. |
| | #47 |
| Registered User New Member | Hi Terry, sorry fo so many question about signcarving from me, but a have big question: Did You made a Router with Plate for friend before like this : ? If yes, i will send You Dollars for the Hardware and your Work. In Germany it's so stuppid to get the right Hardware. If You have no Time. no Problem Thanks so much Albert |
| | #48 |
| Registered User Forum Geek | Hi Albert, Glennmore showed me how to get your name on my contact list on Skype,, when you get a chance to go on there,,, we can chat and I can walk you though that plate,, its so easy to make,, nothing to it,,, I have your name on my list now,, so when you are running skype, your name should light up on my screen,,
| | #49 |
| Registered User New Member | Hi Terry..... Could you tell me ...what size Plexiglas, did you use for the router’s subbase.....and did you use the original screws that came with that trim router. I have the same router and man those screws are really small. any advise on this would be great.....thanks |
| | #50 |
| Registered User Forum Geek | Sorry Rout4you, I missed your post,, I used a piece of Plexiglass 1/4 inch thick about 10 or 12 inches square. You remove the base plate that is on your router, and use that as a template to drill the holes in your new large base plate. Remember, you are NOT putting the original small base plate back on,, but replacing it with the new big plate,so you are not really much thicker then before. You have to counter bore the plate so the screw heads do not stick up above the surface of the new plate,, so the old screws, even though they are not very big, should work fine.
