| | #1 |
| Registered User Forum Geek | I'm having a problem with tear out's when routing smaller patterns through pine (dragonfly is an example). Where the two wings come together to a point (where they meet at the 'body' area), I'm getting pretty constant tear out of the point of wood. I'm using a spiral upcut bit for the cut but it doesn't seem to matter how slow I go, I still get occasional breaking off of the 'point'. Any suggestions? Note: I've tried plunging completely through and also taking stock off in small progressive cuts. Same end result. Thanks. |
| | #2 |
| Registered User Forum Fanatic | Hi Stan,,,, I just happened across this thread and I have an idea that might help. Have you tried turning the pattern and the piece over and routing from back of the piece? What I think might be happening is you might be routing against the grain at the point where the wings come together. You might have to modify your pattern to have an index pin or stop on it so you can locate it in the same place on the back side of your work piece. Give it a try. Chuck
__________________ PopPop If it's worth building, It's worth building well. poppop@routerforums.com |
| | #3 |
| Registered User Forum Geek | Thanks Pop_Pop, I might be able to come up with something that will work based on your suggestion. Thanks agian. |
| | #4 |
| Registered User Forum Geek | I have had luck using pattern bits and flipping the piece over,as was suggested. regards jerry |
| | #5 |
| Registered User New Member | Stan, You may want to try a spiral downcut bit. The way the upcuts work is they pull the mateial from the bottom up and sometimes cause splinering at the top, good for mortising because it keep the hole clean. The downcut bits cut from the top down and will leave a smoother top surface. When the upcut bit is "pulling" the wood up, it is probably breaking off your sensitive point. If you used a downcut bit with a solid flat surface, you will be "pushing" the wood down and the tip should not break so easy. Turning the material upside down may work as well and worth trying before buying anymore tools. Hope this helps. Brian |
| | #6 |
| Retired Moderator Forum Geek | Hello Stan, What about trying a trim router for the intricate parts and you may be able to have a better feel for how much pressure you are applying.
__________________ Regards Randy PC Support Forums, Free on line virus Scan, The Parasite Fight, Subratam.org -> Kill Spyware Forums A.S.A.P. Proud member since 2004 ~ |
| | #7 | |
Don't know if what I wrote makes sence so if not I can do a sketch..... Ed | |
| Looking for intarsia patterns | buckshot | Project Plans and How To | 6 | 10-06-2008 11:11 PM |
| CarveWright Patterns | bobj3 | CNC Routing | 6 | 12-07-2007 09:46 AM |
| Air Compressor Suggestions | mshaf23783 | Tools and Woodworking | 10 | 06-12-2007 09:32 AM |
| Suggestions for Finish | fibertech | The Finishing Touch | 5 | 11-10-2005 11:46 PM |
| Ideas / Suggestions | Mark | Lobby | 4 | 09-20-2004 08:55 PM |
