Thread Tools Display Modes
Old 09-16-2005, 05:20 PM   #1
Birchwood
Sr. Member
Birchwood is on a distinguished road
Question proper bit size
Well fellas....here I am again! I found out this afernoon, to my dismay, that I had purchased the wrong size bit for what I needed to do. So before I waste more money I need your help. I am really intrigued at the idea of using high quality 3/4 ply for make a box with perfect corners, no end grain visible. There are two bit sizes listed for the 45 locking miter bit. Which would be correct for this job.
And. today I wanted to put a 45 on th edge of a piece of 1"oak. Only bit I have is a very nice double flute that is 1/2 shank and (I found) 1/2 cut. I learned that I CANNOT put a 45 on the entire edge of a 1" stick with my bit.Drat and double drat!! What I need is a 1" or BETTER 45, right.
Oh....and one more thing. I am typing without the use of my right index finger. While cleaning a bit I discovered that those cutters are just like razors!! Yikes!!
Birchwood is offline   Top - Reply with Quote
Old 09-17-2005, 12:34 PM   #2
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi, Birchwood: I bought a lock miter bit from Grizzly a long time ago, it handles 3/4" stock. It was one of those bits that you buy thinking you will only use it once, and was'nt expensive. I think I would cut the ply wood at a 45 angle, and use biscuits to join the corners. Watch out for those bits they can cut when not running.
Hope this helps... Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 09-17-2005, 12:54 PM   #3
Visteonguy
Forum Geek
Visteonguy's Avatar
Visteonguy is on a distinguished road
Hi Birchwood,,,, I just looked on Ebay and there is a 45Degree lock miter bit that will work with wood thicknesses between 1/2 inch and 1 1/4 inches,,, right now its going for $23 with just over 6 hours to go in the auction,,
the auction number is 5998921403... if you care to look,,,
also,,, if your peice of wood that you want to miter on a 45 is small enough,,, you could build a jig that would hold your board on the 45 and then you may have a bit that will cut wide enough on its end to get the job done for you,,, but if the board is too big to hold in the jig,,, then so much for that idea....
Terry
It seems like every where I go,,,,,,,,,,,,,,,,,,,,,,,,, there I am...
Visteonguy is offline   Top - Reply with Quote
guide bushing size chart mharwell01 Guide Bushings and Templates 16 03-19-2008 08:32 PM
Router bit and Router size for CNC? macg CNC Routing 17 04-07-2007 01:13 AM
Router Bit Size Marking ? joeohlandt Router Bits - Types and Usage 5 04-06-2007 02:09 AM
Router Table Size? deck99 Table-mounted Routing 4 09-28-2006 10:55 AM
What size is it? Thread size... mountainguy Tools and Woodworking 1 08-20-2006 03:02 PM
