Thread Tools Display Modes
Old 09-24-2005, 02:06 PM   #1
Unisaw
Jr. Member
Unisaw is on a distinguished road
Default Problem with Mitachi M12V bit climb
I bought this machine a while ago and use it for the first time today.
I was routing a rabbet in the back of bookcase standards to receive the 1/2" plywood back. The bit was a Porter Cable rabbret bit with a bottom guide bearing. The shaft was 1/4" --- that's all I could find at HD.
Anyway, I chuck up the 1/4" sleeve in the collet and insert the bit. The router stalled and I noticed the bit was climbing out. I tightened it again and the same thing happened.
I finisihed the job with my PC690 with no problems.
Any thoughts on why this happened? Yes I locked the collet with the sliding metal plate and then wrenched it.
Thanks.
Unisaw is offline   Top - Reply with Quote
Old 09-24-2005, 03:14 PM   #2
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
I would check the sleeve for cracks, and check the collet to see if every thing is clear of rust and or dirt. I hope the collet has not been cross threaded.
Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 09-24-2005, 03:47 PM   #3
Unisaw
Jr. Member
The sleeve does have vertical cracks by design. They allow it to close when the collet is tightened.
Old 09-25-2005, 09:50 AM   #4
steveo
Forum Fanatic
steveo's Avatar
steveo is on a distinguished road
Agreed, I have two M12V's. The so called "cracks" on the 1/4" reducing collet must line up with the "cracks" on the 1/2" collet when inserting a 1/4" dia bit into the smaller collet. This allows for proper contraction of both collets when tightening the smaller bit.
I'm sure that is the problem you are having.
steveo
steveo is offline   Top - Reply with Quote
Old 09-25-2005, 10:46 AM   #5
Unisaw
Jr. Member
Thanks. I did not know that the cracks had to be aligned. The directions with this are less than stellar.
Old 09-25-2005, 08:08 PM   #6
Pop_pop1
Forum Fanatic
Pop_pop1 is on a distinguished road
Hi Unisaw,
I've had an M12V for a few years and found almost immediately that I wasn't comfortable with the slide lock and only one wrench. Initially I had the M12V mounted in my router table. My concerns were realized when a large round over walked out of the collet. Luckly no one was hurt. Since then I have used 2 wrenches to tighten the collet. The second wrench needed is an odd size (23 MM) and hard to find so I made one. Since then I've had no problems with bits, 1/2" or 1/4" shank, walking out. I was too embarassed to call Hitachi and complain.
I believe using 2 wrenches is a more permanent fix to the loose bit problem.
Good luck with it,
Chuck
PopPop
If it's worth building, It's worth building well.
poppop@routerforums.com
Pop_pop1 is offline   Top - Reply with Quote
Old 09-25-2005, 08:43 PM   #7
Unisaw
Jr. Member
Thanks. I thought it was me. I hate the slide lock. It is hard to use and I have a low sense of comfort - translate - I don't have a sense of safety when I lock it down.
Old 09-25-2005, 08:45 PM   #8
steveo
Forum Fanatic
steveo's Avatar
Originally Posted by Pop_pop1
Hi Unisaw,
Good luck with it,
Chuck
The first thing to do when opening a box with a new router is to take the "stamped" wrench that comes with the unit and open the shop door and throw it as far as you can, then get yourself a real wrench or two.
steveo
Old 12-06-2005, 06:48 PM   #9
kenadian
Dedicated Member
kenadian's Avatar
kenadian is on a distinguished road
I plan on picking up 2 [new] wrenches for my M12V; one is a 21mm while the other should be a 23mm wrench. Are these the correct sizes?
I am Kenadian!
kenadian is offline   Top - Reply with Quote
Setting the proper RPM on the Hitachi M12V jrs4464 General Routing 5 01-10-2007 10:34 PM
M12V pricing/seller dtaylor15 General Routing 1 01-28-2006 12:41 AM
Problem with my Hitachi M12V Visteonguy Table-mounted Routing 23 08-19-2005 12:22 AM
Opening size in router table problem glassguy1456 Table-mounted Routing 2 02-28-2005 08:09 AM
Hitachi M12V Router Problem dcarriere Tools and Woodworking 3 12-28-2004 07:50 AM
