Rate This Thread - RouterForums Amateur Night??????.
Thread Tools Display Modes
Old 09-30-2004, 08:33 PM   #31
reible
Supreme Forum King
reible's Avatar
Originally Posted by template tom
From Ed "For those of you new to metric conversion just remember 1" = 25.4mm. Tom's box (and may I add it looks great, tell us about the finish) is just over 7" x almost 4" x 1 3/8" For those going the other way the daffy duck hole is (3" x 5") is about 75mm x 125mm (all dim. rounded"
The box was cut from MDF and was simple painted. I have also produced them in solid timber. Just to get others thinking how it was done I will say that the only tool I used was the router.
Tom
Tom,
let me guess, you used a template??????
May be you would care to share the details in a lesson form for us? I think I know how I might do such a project but I would like to here how you really did it. How about other readers, what to know Tom's secret?????
Ed
Old 09-30-2004, 08:43 PM   #32
reible
Supreme Forum King
reible's Avatar
Default Amateur night pattern basics pt1
This might be sort of a step back in the series on template guide issues but since I have had a couple of more basic questions this might be of some help.
The use of templates or patterns let you route irregular or straight lines into or through your work piece. They can help rout or trim edges, or help clean-up rough sawn profiles. They help do special joints; they help you do things like set in hinges or other hardware. Then there are inlays and well the list goes on.
Maybe you have no idea where to start with this style of routing or what you need to get started. After you have finished this article go back and revisit some of the other posts for more ideas and see if they make more sense now.
For the most basic of operations you need your router and a bit. If you have a plunge router and plunge bit you have an even better set-up. The next add on are the template guides. Depending on your router manufacture they come in all sorts of sizes and mounting styles.
I have an old Sears’s router and the mounting method and sizes of template guides were very limited. I chose to buy a sub-base (that is the often black plastic piece on the bottom or the router) so I could use set of template guides that fit Porter Cable routers. This is some times referred to as the PC or Porter Cable standard. In general this means a 1 3/16 outside diameter two-piece threaded guide bushing. The second piece of the two-piece is a locknut that secures the guide in place. The sub-bases are often listed as universal meaning they fit many routers so there is a good chance they will have one for your router if that is what you choose to do.
The template guide bushings come in various sizes, normal measured by the outside diameter (OD) of the barrel. The inside diameter determines the maximum size bit to be used and keep in mind the bit needs to have some space around it so the bit size is less then the inside diameter (ID). A typical set might have OD’s from 5/16” to 1” or more. They also can be purchased one at a time so you add to your collection.
Next is the issue of barrel length. This is basically the length the barrel protrudes below the surface of the sub-base. Some makers of template guides have various barrel lengths in a set from less they ¼” to 1” (that is as long as I’ve seen). These guides are often used for that manufactures fixtures (dovetail jig, hinge template, stairs template). If you can it is best to look for a set that has all the barrel lengths about .234”. Then ¼” material (or .250”) then works for making the patterns.
Whatever the barrel length or pattern thickness the guide-bushing barrel should not touch the work surface and routers sub-base should be sitting flat on the template.
Cont. pt 2
Old 09-30-2004, 09:43 PM   #33
reible
Supreme Forum King
reible's Avatar
Default Amateur night pattern basics pt2
How about material for making patterns? It is often easies to use ¼” thick material, very simply it is easier to work with, easier to sand to correct ruff surfaces or miss cuts. If you want to test this out take a piece of ¼” plywood and attach it to a piece of ¾” pine. Take a handsaw/jigsaw/?? and cut though both pieces take them apart and sand until smooth. The thinner piece was faster and easier right?
A lot of materials will work, plastics, plywood, hardboard, solid wood, in fact most people chose different materials for different projects. I tend to use plastics for things I want to have around for a long time and hardboard for a lot of the other projects. Hardboard has the advantage of being cheap, I get a 4’ x 4’ piece and cut pieces out for a project and store the rest. (I should point out that I combine solid wood to make the pattern in to fixtures.) Others use only plywood or only plastic so the choice is yours and you will only know what is best for you after doing some work with it.
You can cut patterns using the router, jigsaws, Dremel tools, coping saws, hole saws, drills, and any other tool you chose to use. Depending on the method used to cut the pattern you might be able to use it as-is or additional shaping and smoothing maybe required. If the surface is ruff and uneven the template guide will follow the pattern and produce the same effect on your work piece. Since you will often use the template to make several of something it pays to get it right so you have less work to do on the work piece when you are finished routing.
You will also see people using bits called “pattern bits”; they have a bearing(s) at the end of the cutter, or at the top of the cutter, or even above and below the cutting area. The bearings are the same diameter as the bit so as the bearing follows the pattern the cutter produces the same edge as the pattern. If you use these bits then the template is subjected to additional wear and maybe even burning or trimming because of misadjusted heights. These bits tend to be costly, the bearings can overheat and or freeze and could add addition cost over the life of the bit (the bearings are replaceable). (Think about the bearing rotating at 28,000 rpm’s and having it contacts the stationary template where it will touch and stop… really something hey?) Please don’t get me wrong the pattern bits offer a lot of advantages as well and are a good investment. What I’m trying to point out is that the template guides wear the pattern out a lot less then a spinning bearing.
I hope this helped with some of the more basic issues. If you still have questions there are a lot of good answers at the routerfourm……
Here is a closing thought for you:
Routers do not make square corners but patterns can.
Ed
Old 10-01-2004, 02:15 AM   #34
reible
Supreme Forum King
reible's Avatar
Default Amateurs Night more template guide stuff
For tonight project let us say that you have decided to make a document frame so you can display that nice award you were given by the Daffy Duck Association. Your birdhouse won first place at the national convention. Good Job! (Again this might be an exercise best carried out in your mind.)
The award had a nice border of raised gold; radius corners and you figure out that you want the frame to have a 5/8” radius corner to show off the gold border. (See attachment 1)
Since you are going to win again next year and for a lot of years to come you want to make a bunch of these frames. Time for a template! You are in a hurry so you make up a rectangular template of the correct size and put some scrape stock in and route away… You picked out a 1” template guide and ¼” bit. When you finish the first corner you see a problem. You forgot about that 5/8” radius corner and you have well a very small radius. (See attachment 2)
OK this is not to bad, so you make a new template and add that 5/8” radius, now you have it… More chips fly as you do another test. Well you have a bigger radius now, but it still doesn’t look right and when you check it is not what you expected. (See attachment 3)
What happen here! Then you think about what you are doing and it comes to you! The template guide puts the bit 3/8” from the template so in order to get the 5/8” radius you will need to add the 3/8” to the 5/8” and make the template with a 1” radius. Now before you look at the next attachment, are you right? OK now take a look. (See attachment 4)
Great work! It is now to late to do the frames so you clean up and days go by, then a week, then one day you decide today is the day, you are going to finish that project. But wait did I use the ¾” template guide or was it… Well here is the ¾ template guide and here is the ¼” bit, that must be it, hey it will work, I know my router stuff…. Now before you look at the last attachment, will this work? Is that your final answer? Ok take a look at attachment 5.
How well did you do? Do you know why this happened? If you wanted to use the ¾” template guide and ¼” bit what radius do you need?
Remember to mark your templates with the bit size and the bushing size.
Ed
routerforums-amateur-night-sample-1s.jpg  routerforums-amateur-night-sample-sq.jpg  routerforums-amateur-night-sample-625.jpg  routerforums-amateur-night-sample-1000.jpg  routerforums-amateur-night-sample-switch.jpg
Old 10-01-2004, 04:49 AM   #35
template tom
Forum King
Consideration will have to be given as to what cutters and template guides are used Another problem that will have to be solved is how is the material held secure during the process. What other tools and machinery will also be required.
Old 10-03-2004, 05:13 PM   #36
template tom
Forum King
Originally Posted by reible
Tom,
Ed
You are correct just a simple template what has to be considered is the cutters used the varous template guides required and how the material is secured during the process maybe too long a posting to submit here unless you may have an easier method Ed to produce the box
Tom
Old 10-03-2004, 05:53 PM   #37
reible
Supreme Forum King
reible's Avatar
Tom
Tom,
Maybe you could not get into all the details and don't try to do it all in one post. Make it more of "mental routing" then actual. Details like bits you use could be in a list:
spiral 12mm
bowl bit ??
I don't think you need actual dimensions or shapes people can do that on their own.
You could even make it real simple like "I do the outside first" etc without many details then people can say "how did you clamp that oval?" a more interactive posting. Just a few thought I had.
Ed
Old 10-03-2004, 06:54 PM   #38
template tom
Forum King
Tom,
spiral 12mm
bowl bit ??
Ed
Here are the first two stages Pic 1 Stage 1 with stage 2 pic 2
routerforums-amateur-night-elliptical-box-base-5.jpg  routerforums-amateur-night-elliptical-shaped-trinket-boxes-base-external-2.jpg
Old 10-05-2004, 06:00 AM   #39
template tom
Forum King
I should have added the cutter used was a 19mm (3/4") dish cutter to rout the internal section then a 10mm straight cutter to rout the external edge
Tom
Old 01-08-2007, 02:19 PM   #40
bagman8
New Member
bagman8 is on a distinguished road
Default Re: RouterForums Amateur Night
Rayinthe UK - I did a page a little while ago where I put together some tips intended for beginners - - hope it's not too basic and the emphasis is on safety.
Ray
Thanks Ray
Your Tips were GREAT
Since I am an amateur, I have really loved this posting. If I am readings correctly - I owe reliable a great debt of gratitude
as well as everyone who has contributed to this.
Ed Baggett
(I was a credit manager and one of my fellow workers named me Bagman and it stuck).
bagman8 is offline   Top - Reply with Quote
Router forums tall tails reible Lobby 11 03-03-2008 11:22 AM
Sunday Night deals from Sears bobj3 Lobby 0 01-27-2008 09:45 PM
New Saturday Night Line Up For DIY Net challagan Lobby 4 02-25-2007 07:42 AM
What a night! -Sam- Lobby 10 04-28-2006 07:46 PM
RouterForums Amateur Night Rabbet bit Tables reible General Routing 1 10-10-2004 09:03 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
