| This is a discussion on Craftsman 315.17390 within the General Routing forums, part of the Routers category; Can anyone tell me how to seperate the base and motor on this thing? I ... |
| | #1 (permalink) | ||
| Forum Contributor ![]() |
Can anyone tell me how to seperate the base and motor on this thing? I inherited it from my father who seldom, if ever used it. He was more interested in metal. Naturally, no owners manual and it is discontinued on the Sears site (imagine that ). I have also Googled and Binged with no luck. I'm kinda resurrecting this thing to use as a second router for dovetails and such. Got a Milescraft turnlock base and bushing kit in this morning and went to work on it. Went to seperate the motor and base to better clean it up when I hit a stop sign. Don't feel I really need the whole manual as most of the operation is pretty intuitive, maybe a couple of adjustments I don't know about. Depth adjustment is pretty sloppy but I think that's gonna happen because of the design. I think some adjustment on the clamp bar may be in order though.Thanks
__________________ John Schaben ![]() The problem with experience is I usually get it immediately after I need it. | ||
Sponsored Advertisement - Register now to remove this advertisement.
** Please be sure to read our Disclaimer at the bottom of the page. **
These advertisements are only displayed to guests, register now for your FREE account on the worlds largest router and woodworking community! |
| | #2 (permalink) | |||
HI John Some turn out and some slip out BUT why if it's working just let it be just blow the ring out real well and put it to work..![]() You don't need the manual it's easy router to use ![]() =========== Quote:
__________________ "It's fine to disagree with other members as long as you respect their opinions" MANY,MANY help files on John's web site http://legacy.woodshopdemos.com/menu2.htm Sommerfeld Tools ,Videos http://www.youtube.com/channel/UCT-n...RWaEpMA/videos | |||
| | #4 (permalink) | ||
| Forum Liaison ![]() |
I suggest you do not remove the motor from the base unless a repair is needed. Some versions have ball bearings between the motor and base, and trust me... you do not want to be chasing them and trying to replace them.
__________________ Mike "Living in the D" (this means Detroit!) "It's fine to disagree with other members as long as you respect their opinions" | ||
| | #5 (permalink) | |||
Anyway, all's well, almost. Now the Milescraft base I put on is gonna give me an issue using it as a second router for dovetails. Milescraft is 7" and my Hitachi is 5-3/4". That means I will need to reset the jig fence every time I switch back and forth......NOT. will figure something else out. Maybe put a Milescraft on the Hitachi also. I really like the turnlocks. May get a set of the nylon ones to cut the noses down on. I like to make my templates out of hardboard and it is getting thinner and thinner. Last stuff I got from HD said 1/4" on the display, 3/16" on the label and 5/32" on the mic. Instead of 1/4" minus something, its 1/8" plus something. ![]()
__________________ John Schaben ![]() The problem with experience is I usually get it immediately after I need it. | |||
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 17 | 10-11-2012 05:20 PM |
| Craftsman Tablesaw with Router wing | rjhanby | Table-mounted Routing | 1 | 08-27-2009 11:10 AM |
| dust extraction for craftsman routers | headclansman | General Routing | 2 | 08-01-2009 10:29 AM |
| craftsmen router? | rhe8542 | Starting Off | 21 | 04-20-2009 10:51 PM |
| Porter Cable vs. Craftsman | rprice54 | Tools and Woodworking | 7 | 01-17-2006 10:16 PM |
