Thread Tools Display Modes
Old 10-14-2005, 03:24 PM   #1
Enticer
New Member
Enticer is on a distinguished road
Default Hitachi M12V overheating
I was using my router to put some round over on approximately 20 pieces of MDF the other day and when I finished I noticed that my router was extremely hot. So hot that you could not put your hands on any metal part not just the bit and collet but any part on the router. It's a wonder that none of the plastic melted.
It never slowed down and still works fine but I can't imagine that this is normal.
Enticer is offline   Top - Reply with Quote
Old 10-14-2005, 06:40 PM   #2
kp91
Forum King
kp91's Avatar
First Name: Doug
mdf is actually quite a workout for a router. A couple of causes of your over heating could be:
1. too heavy of a cut (either too deep or too fast)
2. bit too far into collet, conducting heat directly from bit into router shaft.
3. mdf dust clogging air passages, preventing proper cooling (especially if in a table mounted operation)
4. You not taking a coffee break halfway through and giving the motor a chance to rest (only kidding)
5. bad bearings (how free does the motor turn when unplugged?)
Try blowing out the housing with clean dry air, just to make sure your router isn't clogged with dust. You could also check how much air the motor fan moves by running your router without a bit in it and feeling the airflow. If is still gets really hot, their might be a bearing issue.
1 John 1:9
1/4" Collet for Hitachi M12V RzzB General Routing 37 05-27-2008 09:11 AM
Setting the proper RPM on the Hitachi M12V jrs4464 General Routing 5 01-10-2007 10:34 PM
Hitachi M12V and Bosch 1619EVS routers LBrandt Table-mounted Routing 3 06-03-2006 11:42 AM
Hitachi M12V issue Warren White General Routing 4 03-23-2005 11:03 PM
hitachi m12v and spiral upcut bit routerman1969 General Routing 1 02-19-2005 06:08 AM
