| | #1 |
| Registered User New Member | I want to know what bit will cut a beaded corner on a table leg with a 1/8" step (i.e., inset) into the bead and a 1/4" radius on the bead? That is what is called for in the design I am following. The tech support at Rocklers suggest I use their #91505 beading cutter (1/4" radius, 1/2" height) and replace the standard 3/8" diameter bearing with a 1/4" diameter bearing. I suppose that will work, but is there a standard cutter that will do the job without modifying it? I have looked at the list of Freud beading bits, but I don't know enough about the terminology to know if one of them will work - for example, they list the bearing diameter but not the small cutting diameter - maybe I can deduce it from something else. I need a course in bit terminology 101. |
| | #2 |
| Forum Moderator Supreme Forum King | Sounds to me not sure but a ogee bit might fit the profile that you are looking for. Try this link that I got from Sam I am might help it gives the different profiles. Hope this helps you out. www.carbide.com
__________________ Glenmore Days without wood working are days not worth getting up for. Last edited by Glenmore; 10-16-2005 at 10:19 AM. |
| | #3 |
| Registered User Forum Geek | Check whiteside, mls, magnate and any other bit makers you like 1/4 r beading bits are very common. regards jerry |
| | #4 | |
| Registered User New Member | Quote:
