router vs. dado for a rabbit cut - Router Forums
post #1 of 5 (permalink) Old 10-23-2009, 09:12 AM Thread Starter
I am in the process of planning out the construction of a large set of bookcases. The back panels of each case needs to be set into a 1/4 inch rabbit that will be cut into the sides and top panels of the bookcase. Does anyone have an opinion on the best method for cutting this 1/4 inch rabbit. The router or a dado blade on the table saw. Thanks.
vmerlino is offline
post #2 of 5 (permalink) Old 10-23-2009, 10:05 AM
AxlMyk's Avatar
Either would do the job equally well. It all depends on what you feel more comfortable with.
AxlMyk is offline
post #3 of 5 (permalink) Old 10-23-2009, 01:59 PM
curiousgeorge's Avatar
First Name: George
Mike is correct. It depends on your comfort level with either tool. However, I would suggest that on larger or longer pieces the table saw dado combination would be easier to handle.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #4 of 5 (permalink) Old 10-23-2009, 05:46 PM
TwoSkies57's Avatar
Just a couple more cents for ya..
If you have the right setup for your router or a router table to make the dado's, I'd go with routing them out.. You can can't beat the smooth bottoms. If the panels are too ackward to handle, then definately play it safe and make use of your tablesaw's large surface..
TwoSkies57 is offline
post #5 of 5 (permalink) Old 10-23-2009, 07:45 PM
First Name: gary
I agree with 2 skies. Just for Dados and rabbetts I bought the
Festool Multifunction Table and their router. Wrestling a piece of plywood on a tablesaw is not my idea of fun.
Especially when that Dado-stack of blades is running without the benefit of a blade guard.
Gary Curtis
garycurtis is offline
Human Verification
Intro and question john spies Introductions 19 02-28-2014 12:55 PM
New Router my way reible General Routing 20 11-30-2011 11:18 AM
Hello DPugmire Introductions 5 11-08-2010 06:29 AM
New here burlboy Introductions 9 01-15-2009 11:53 AM
