| | #1 |
| Registered User New Member | I have been routing relief carving type signs lately, but am having problems keeping the routed out areas flat. I end up having to sand out all the small rings and trails that the router bit leaves behind. I use a straight plunge bit to route out a flat area. Are the rings and trails caused by the router's vibration? Is there anyway to minimise this? Does anyone have any tips? Thanks (my first post) Victor |
| | #2 |
| Registered User Forum Fanatic | Hello Victor, I have in the past routed out many relief signs and found the same problem as you. My cure is to use a small chisel upright at 90 degrees to the wood and use it like a cabinet scraper. This does take a little time and patients but is worth the effort. I hope this is of some help to you. ![]() |
| | #3 |
| Registered User Forum Geek | If you have the room use a flat bottom bit,use the one called a bowl and tray bit it has radiused edges. I haven't used for signs,but have for inlays and it does a fine job. Relax take your time and enjoy the work. Regards Jerry |
| | #4 |
| The Router Guys Forum King | Jerry has it right the flat bottom bit is the best bit to use when you want a smooth surface.
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. |
| | #5 | |
| Registered User New Member | Quote:
| | #6 |
| Registered User New Member | Thanks for the tip. I will give it a try. |
| Freehand routing | Visteonguy | General Routing | 50 | 09-08-2008 01:26 AM |
| Looking for a FLAT SUB-BASE for PC894PK | Benny LaBaw | General Routing | 48 | 10-25-2007 01:53 PM |
| Dust Colection for routing Dados | KentWW | Table-mounted Routing | 3 | 01-10-2007 03:18 PM |
| Routing Template | Verlin Garrett | Jigs and Fixtures | 5 | 02-06-2006 04:43 PM |
| Routing end grain | Pop_pop1 | Table-mounted Routing | 8 | 09-22-2004 01:24 PM |
