| | #1 |
| Registered User New Member | Greetings- I'd like to overlap two 3/4" plywood panels using a slot in each- so that the end result when viewed edge-on from above would look like an "X" or cross. Can these slots be safely cut with a router, or should I stick to a jig-saw? If using a Makita 3.5hp router with a 1/2" shank straight bit, do I need to make multiple passes to cut the slot? Thanks, a woodworking newbie |
| | #2 | |
| Retired Moderator Forum Geek | Quote:
![]() You can safely cut them with a Router but it would need to be done in Multiple passes, take your time, donot force it and use a straight edge so you can cut the slots straight. To me the quickest and easiest way would be with the jigsaw. What ever you decide just becareful and clamp your work down.
__________________ Regards Randy PC Support Forums, Free on line virus Scan, The Parasite Fight, Subratam.org -> Kill Spyware Forums A.S.A.P. Proud member since 2004 ~ | |
| | #3 | |
| Registered User Forum King | Quote:
Tom | |
| | #4 |
| Registered User New Member | Hi, I did exactly this recently with 1/2" MDF. I used a 1/2" straight bit, clamped the two pieces together, and ran along a straight edge to the halfway point plus a sixteenth or two to account for the rounded edges. I ran it in 3 or 4 passes and it came out perfectly. If your bit width matches the thickness of your plywood (3/4"), this should work for you too. If you are using a smaller diameter, you would be better off using a template and edge bushings. Whichever way you need to go, make multiple passes, especially if you clamp the two pieces together. Good luck with it. Art |
| | #5 |
| Registered User New Member | Thanks for the help everyone. Great idea Wanart, clamping the two panels together to cut the slots. |
| Fastest Bit for cutting 1/2 Plywood??? | nicksorenson | Router Bits - Types and Usage | 2 | 06-02-2008 06:19 PM |
| Best Router for Cutting Slots - Slat Wall | RAKESS | Table-mounted Routing | 0 | 01-27-2008 04:36 PM |
| Squaring plywood panels | ShaneB | Table-mounted Routing | 37 | 12-22-2006 07:40 AM |
| cutting slots | Grandpasworkshop | General Routing | 4 | 10-22-2006 07:59 PM |
| cutting plywood on a 45 with a router | joe carter | Tools and Woodworking | 2 | 10-24-2005 07:00 AM |
