Help
Problem mounting Dewalt Router to Caftsman Table Saw
This is a discussion on Problem mounting Dewalt Router to Caftsman Table Saw within the General Routing forums, part of the Routers category; Hi All, I needed help mouting a Dewalt Router to a Sears Table saw with ...
Old 12-03-2005, 11:42 AM   #1 (permalink)
apollo2000 is on a distinguished road
Default Problem mounting Dewalt Router to Caftsman Table Saw
Report Post Report This Post!
Hi All,
I needed help mouting a Dewalt Router to a Sears Table saw with router kit, any idea.
One day I was in Sears and they had a good quality cast iron table saw for sale with a hole at one end to attach a router.
So thinking it was a great deal – two in one package I bought it.
At that time I was considering buying a Porter Cable router but since they did not have any in that store, I bought a Dewalt Router, what I was told by the sales guy was a good router and it did look good as it has a plunger feature that can be removed. The sales guy told me that the holes were standard on the table and will accommodate any common brand routers.
Well the table saw took me a long time to assemble as it has all legs made of multiple plates, etc and is heavy as it is built drive. By the time I got to try to fit the router to the table it was over 30 days since I bought it, the router holes don’t line up at all and screws do not fit either and Sear will not credit me as it is over 30 days.
So I went to the store and they sold me a square plastic plate and said that would work. But that did not work either as the cast iron table has a round hole about 2 inch in diameter and not a big square plastic plate as found on most router tables. Also the screws that come with the router are too short to go through that thick castiron top.
Anyway, the bottom-line is that I cannot mount the new Dewalt Router on to that table- do you have any suggestions as to how I can make this work.
After a long time I went to another Sears store last week and asked the same question and the sales guy told me something unbelievable- he told me that I needed to drill holes in the cast iron table saw top to make my Dewalt Router Fit.
apollo2000 is offline
Old 12-03-2005, 12:41 PM   #2 (permalink)
Glenmore's Avatar
First Name: Glenmore
Glenmore has a spectacular aura about
Send a message via Skype™ to Glenmore
Welcome to the forums apollo2000. I think you should go back to sears and get a manager. The problem with crapsman most of the time is that when you buy their brands you have to stick to their brands they usally don't make some things interchangable. I would go and tell them that you were told wrong about for one thing that all base plates are different for mounting. Porter cable won't hook up to a black and decker base or vica-versa. So you got miss led in my veiw. I won't go drilling holes through it either might heat it and warp it. Sounds to me the dewalt if you can't take it back will be a nice one for hand held working and if you ever up grade to a better table you could use it for your new table when the time comes. Hope this helps you out.
Glenmore
Days without wood working are days not worth getting up for.
Glenmore is offline
Old 12-03-2005, 02:01 PM   #3 (permalink)
Hickory's Avatar
Hickory is on a distinguished road
I would take the DEwalt router back and get the porter-cable It was there mistake, not yours , they should be able to exchange routers, and make sure they are of equal value..Not sure what dewalt you got..DW616 or 618.If they have a saw there on display make sure it fits. Do not drill holes in your saw top.
If you cannot get anywhere with them, then if you did get the Dewalt Combo with 2 bases..you could have the fixed base , drilled and tapped to fit..It will not ruin the base., But the holes have to be right on too line up.
An adapter plate will also work but you will lose some router bit height.
I would FIRST go down hard on the store ..thats your best option , they sold you 2 pieces that will not work together..the 30 days doesnt mean anything..get the manager involved and if he wont do anything go higher.
You should have to waste your time, trying to match up too pieces that are not meant to be..
Also sears Craftmen routers are made by Skil Skil also makes Bosch.I really wonder if Porter-cable will fit the table. If so great, but if they are wrong again, go for a Bosch 1617 combo package.
Hickory
Hickory is offline
Old 12-05-2005, 09:40 AM   #4 (permalink)
Thanks for you feedback.
I guess I need to find the right Sears Manager who will listen. I guess I will not be buying any craftsman electrical tools anymore.
Old 12-10-2005, 12:42 AM   #5 (permalink)
Delta6mike is on a distinguished road
Hickory is exactly correct when he tells you to go to management at Sears. Please go up three levels of management, thank level one and level two with a " I understand that you do not have the authority to solve this problem; please let me talk with your supervisor.". I know this is a time consuming approach, however, it has been my experience that polite persistence will overcome "written in stone policy" everytime. Occasionally you may have to go to level four but not often. Good Luck, Erich.
Delta6mike is offline
Old 02-13-2007, 07:42 AM   #6 (permalink)
brownfoot is on a distinguished road
the hole pattern for a C-man router, using the 3 #10 flathead screws fits C-man routers (made by Ryobi), the small Skil routers use the same pattern and one of the C-man routers is made by Skil, but only in a combo-kit with a router table
the P/C should fit also
are you wanting to use a larger (1/2" shank bit) router?
the 3 larger holes are for the C-man router (5/16" flathead screws) in an "L" pattern
on drilling your own holes, there is no problem with drilling the cast iron, especially the small holes that you need on that large a plate, 500 rpm max, no cutting oil.
brownfoot is offline
Old 05-18-2007, 01:00 AM   #7 (permalink)
Drugstore Cowboy's Avatar
Drugstore Cowboy is on a distinguished road
I'll put in my .02 not as someone who knows that much about routers and hole patterns etc. But I DO know a thing or two about retail having worked in several major stores - including Sears - over some 30 years.
I can tell you - there are PLENTY of people with the authority to tell you - no - regarding correcting an error like this. Far fewer with the authority to say -yes-.
A GOOD salesman would have acknowledged this and helped you up the chain of command til you found someone who could resolve the issue. One satisfied customer - especially one who brags about how so-and-so went out of their way to resolve a problem is worth THOUSANDS in ads.
Unfortunately - your salesman chose not to -- and left it up to you.
As others have pointed out -- you keep pressing -- and you will find someone who will make it right -- Heres hoping you already have.
Drugstore Cowboy is offline
Old 05-18-2007, 03:54 AM   #8 (permalink)
Mike will become famous soon enough
Since this posting is 2 years old I do hope the problem was resolved. For anyone new to the forums here is a rule about Sears products that is true most of the time: If you buy a Craftsman product odds are it will need Craftsman accesories to work. Most of the sales people at Sears are not woodworkers and do not honestly know what works together and what does not. If you buy a table and router they say will work together have them show you in the store before you hand over your money.
As always, we here at the forums will do our best to assist you with problems in dealing with a manufacturer. The voice of 12,000 members and 2,000,000+ visitors is often loud enough to get results.
Old 05-22-2007, 07:42 PM   #9 (permalink)
Zuki's Avatar
Zuki is on a distinguished road
You mention a SQUARE mounting plate. Did you try the round adaptor plate? I bought one several years ago to mount my Dewalt router to a Craftsman table. Worked like a charm. I actually had to buy another today as I busted that one up trying to mount it to a Mastercraft table. Only $14.
Loyal
Zuki is offline
Vertical mounting of baseplate on router table raybo Table-mounted Routing 3 01-22-2008 02:46 PM
mounting table plate to router dthompson Table-mounted Routing 13 12-05-2007 04:05 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
Mounting Porter Cable 892 Fixed Base to Router Table Pack52 Table-mounted Routing 4 02-14-2006 05:50 PM
Opening size in router table problem glassguy1456 Table-mounted Routing 2 02-28-2005 08:09 AM
