Thread Tools Display Modes
Old 12-15-2005, 10:12 AM   #1
mblanc
New Member
mblanc is on a distinguished road
Question Question About Smoke
This is probably a dumb question, but...
I have a pretty old Skil model 1823 router, and I get a lot of smoke when using it.
The smoke isn't from the motor, but from the wood. To the point where my wife is referring to the router as "that tool you use to burn letters into the wood."
I know the way to stop this is to make multiple passes, cutting less wood at a time, and I try to do this. I also keep my bits as clean as possible.
But my question is, would a more powerful motor reduce this problem?
mblanc is offline   Top - Reply with Quote
Old 12-15-2005, 10:20 AM   #2
Glenmore
Forum Moderator
Supreme Forum King
Glenmore's Avatar
Glenmore will become famous soon enough
Send a message via Skype™ to Glenmore
Sounds like your bits are extremely dull. How old is the bit you are using they do loose there edge eventually.
Glenmore
Days without wood working are days not worth getting up for.
Glenmore is offline   Top - Reply with Quote
Old 12-15-2005, 02:39 PM   #3
mblanc
New Member
Another question - I assume a dull bit could be sharpened with a file, but it probably makes more sense to replace it?
Old 12-15-2005, 04:44 PM   #4
Gilbear
Supreme Forum King
Gilbear's Avatar
Gilbear is on a distinguished road
I agree with Glenmore - sounds like dull bits to me too - or else you're routing your passes wayyyyy to slow (doubt that) - I believe there are some power sharpening devices out there but have never used one - I'd be leery of trying with a file by hand - for me, I'd replace it - and the ones that would seem too expensive to replace are the ones that might the biggest disasters to file (like panel bits, lock miters, etc). Maybe someone who has used the power sharpeners would have some insight for you?
Gilbear is offline   Top - Reply with Quote
Old 12-15-2005, 05:32 PM   #5
Hickory
Sr. Member
Hickory's Avatar
Hickory is on a distinguished road
Burning can be alot of things..the most powerful router can burn.Could be bits, could be speed of motor or speed of operator..
Sometimes it hard to control the burning especially on end grain.
Hickory
Hickory is offline   Top - Reply with Quote
Old 12-16-2005, 01:17 AM   #6
reible
Supreme Forum King
reible's Avatar
Hey here's my take on this. And it is really no different then what other have said. My first guess is that the bit is really dull, if it is HSS and got hot enough to burn the wood the edge is most likly in really bad shape and a new bit would be well worth it. If it a carbide bit it could be sharpened but by the time you find some place to send it in to have it done it might cost as much as a new bit........ bottom line get a new bit.
It sounds like you might be trying to do wood burning and signs at the same time... so now comes a few other things that can cause problems, things like not using a plunging style bit, this would mean the burning occurs when you start the cut but clears up as you are moving along. You could be moving to slow, taking your time to get the job done might mean doing it in two passes or three rather then one deeper slow one. This leads to just how deep are you trying to do in a single pass.... to deep is not good.
The other problem could be the material you are routing. Some materials are very hard to work and dull tools very quickly.... This is also an issue with what type bit you are using, HSS will dull much faster then carbide and things like glue really dull those bits quickly.
Just for the record grinding bits is not something most of us will ever do, some bit have very complex angles and rakes that take fancy machines to deal with. A standard file is not going to touch up a carbide bit, you would need diamond files for that...
More horse power is not going to help..... slower speeds are not going to help as long as you are using smaller bits, they need to spin fast. One last thing, make sure the bit is not all the way to the bottom of the chuck/collet as the motor can transfer heat to the bit or so I have been told.
Lots of bits on sale on-line........
Ed
Old 12-16-2005, 02:34 PM   #7
CASparky
Member
CASparky is on a distinguished road
Nothing really new here, either... Just my experience(s)
My first attempts at using a rounter were exactly the same, (HSS bits back then).
I will not go into router problems here (I shall on the Router Poll), however with my third router, I started using nothing but carbide bits - WHAT A DIFFERENCE!! (Actually I first tried just one in my second router!) Super clean cuts, nice chips, and NO SMOKE!!, when routing at any speed! Prices of carbide bits have come down greatly and the difference in cost is worth it on the first use!!!! I find sticking with bits one can obtain ratings or opinions on - tend to perform the best. Bits alone convinced me to go from 'never (even) wanting to use a router', to 'what project can I do next?!!', and I work more with metal than wood.
I would suggest looking into buying bits in a set, with all the bits included that one intends on using in the future.
Good Luck, Lou
CASparky is offline   Top - Reply with Quote
Old 12-16-2005, 10:55 PM   #8
Hickory
Sr. Member
Hickory's Avatar
Get yourself some Carbide upspiral bits . You wont be disappointed . I dont even use the straight bits anymore..
Hickory
Old 12-17-2005, 08:24 AM   #9
Pop_pop1
Forum Fanatic
Pop_pop1 is on a distinguished road
Hi Mblanc, First of all, Welcome aboard.
Since you said you have a very old router, I'll assume you also have very old router bits. If the bits you're using are HSS and have solid guides rather than ball bearing guides, it is very easy to burn your work piece by putting too much pressure against it while cutting. If the router is pushing off of the cut, you should route in the other direction. The router should pull it's self into the cut, not push away.
To elaborate on onother point already mentioned in several replies, you should only hone a router bit on the flat face of the cutting edge, never try to sharpen on the contour of the bit. This is true for both carbide and HSS bits. The only difference being, the carbide requires a diamond file (hone). If you or someone else has tried to regrind or use a file to resharpen the contour of the bit, replace it.
Work safe.
PopPop
If it's worth building, It's worth building well.
poppop@routerforums.com
Pop_pop1 is offline   Top - Reply with Quote
new omnijig user with a question dracjm Introductions 1 06-29-2008 03:09 PM
DC Question angus Lobby 3 03-31-2008 08:29 PM
Craftsman Router Question fibertech Portable Routing 4 05-09-2005 05:49 PM
Question about T-Slot Bit for router table fence. ryan.s Table-mounted Routing 5 05-02-2005 06:42 PM
Question: Sub Base Plate and guide bushings trap General Routing 3 04-17-2005 08:25 PM
