| | #1 |
| Registered User | Where can you find a second wrench for the Hitachi M12V router? The one-wrench-spindlelock is a knuckle buster.
__________________ Gary |
| | #2 |
| The Router Guys Forum King | Gary: Makita has the 23 mm wrench for sale. Don't know the part number but I know they sell the wrench.
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. |
| | #3 |
| Registered User New Member | Gary, I assume you are using the M12V in a router table? If so, Sommerfelds tools for wood seels a bent wrench for use with the m12V. It allows you to change bits from above the table without removing the router from the table. I use mine in a Sommerfeld table with the wrench and can't live with out it. Their website is www.sommerfeldtools.com. I don't work for them, just have some of their products which I do like very much. I hope this helps. Clay |
| | #4 |
| Registered User Forum Fanatic | I have a M12V. Look arount at flea market or pawn shop and pick up a 21mm and a 24 mm open end wrench(s). A friend of mine took the 24mm to work and "thinned" it out on a mill. Of course I always take my router out and on top of the table to change bits the same way Bob and Rick did on the series when they used their M12V's. |
| | #5 |
| Registered User Dedicated Member | I plan on picking up 2 [new] wrenches for my M12V; one is a 21mm while the other should be a 23mm wrench. Are these the correct sizes? Thanks
__________________ I am Kenadian! |
| | #6 |
| Registered User Forum Fanatic | Yes Kenadian 21mm &23mm are the correct sizes.
__________________ PopPop If it's worth building, It's worth building well. poppop@routerforums.com |
| Two wrench method- one wrench router | Delta6mike | General Routing | 63 | Today 12:52 AM |
| Hitachi MV12 two wrench system | cbsjoez1935 | Table-mounted Routing | 15 | 04-22-2007 06:51 AM |
| Setting the proper RPM on the Hitachi M12V | jrs4464 | General Routing | 5 | 01-10-2007 10:34 PM |
| M12V Wrench | shanohano | Tools and Woodworking | 1 | 07-13-2006 08:24 AM |
| M12V pricing/seller | dtaylor15 | General Routing | 1 | 01-28-2006 12:41 AM |
