Thread Tools Display Modes
Old 01-04-2006, 12:58 PM   #1
fade2black
New Member
fade2black is on a distinguished road
Default Sharpen a spiral bit
I own a small acrylic fabrication business and have a questions about sharpening bits. I almost exclusively use a solid carbide, 1/2" shank spiral flush cut bit for everything I do. I router thousands of feet of acrylic every year and go through about 3-4 of these bits in a year. They dull fairly quickly and I can only get a few months out of them before they are just too dull to use anymore. I have asked a few places and they are telling me there is no place that can sharpen a spiral flush cut bit. I just figured I would ask the router experts here and see if that is truely the case. At $60-70 a pop, buying these bits adds up over time. I use these in a router table with a downdraft dust collector, so if there is a better option, I am all ears.
Paul
fade2black is offline   Top - Reply with Quote
Old 01-04-2006, 02:45 PM   #2
moreorles2000
Dedicated Member
moreorles2000's Avatar
First Name: les
moreorles2000 is on a distinguished road
i used 2 work in a tool crib for a machine shop & they used to send their bits both HSS and carbide out for regrinding all the time i am in canada but could check where they send them for resharpening.
les.
Paul
moreorles2000 is online now   Top - Reply with Quote
Old 01-04-2006, 06:58 PM   #3
delroy33
Supreme Forum King
delroy33's Avatar
delroy33 will become famous soon enough
If you use this flush trim bit with the bearing the bearing Diameter must be the same as the resharpened flush trim bit.
Dont think you can get the bearings that way.
when the bit is resharpened it becomes smaller in diameter and the bearing will be larger.
roy
start square, finish square
delroy33 is offline   Top - Reply with Quote
Old 01-05-2006, 06:56 AM   #4
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi: I have all my bits and saw blades sharpened by Forrest Mfg. they are located in NJ. They sharpen all bits including the spirals. I suggest that you contact Infinity tools
they are in Fla. 877-872-2487. I buy bits from them and they usually have good prices.
The bits are made in the US. You could ask them if they provide a sharpening service also. Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 01-05-2006, 10:25 AM   #5
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
I don't think that the flush trim bit can be sharpened. The diameter of the cutting edge needs to be the same as the bearing. Sorry Rick
Rick and Bob
The Router Guys
Old 01-05-2006, 11:29 AM   #6
fade2black
New Member
That's what I was thinking, but can't they use a smaller diameter bearing and sharpen the bit til the diameters match?
How about normal flush cut bits that aren't spirals? Anyone sharpen those?
Thanks for the replies!
Paul
Old 01-05-2006, 12:04 PM   #7
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
Again Paul the cutting edge needs to match the bearing, right.
Rick and Bob
The Router Guys
Spiral Bits/splinters George II General Routing 5 01-29-2008 11:50 AM
Spiral up or spiral down slumlord Introductions 6 12-14-2007 01:54 AM
Removing material with an up cut spiral bit? Nickbee Router Bits - Types and Usage 10 12-02-2007 04:02 PM
spiral bit woodendigits General Routing 2 09-04-2006 12:15 AM
Spiral bits? archer_456 General Routing 6 04-11-2005 11:31 PM
