| | #1 |
| Registered User New Member | Hi, I'm trying to get my foot in woodworking, and I got a router for Christmas and I've already thought out my first big project using it, and I went out and bought myself some bits, two that are for 1/2" collets (is that the correct term for the thing that holds the bit in place?) and one that is for 1/4" collets. My Skil comes with a 1/2" collet and a 1/4" adapter sleve, but none of my bits, not even the adapter sleve that it came with, fit. The collet tapers near the top and it tapers just a tad too much to the point that I can't get my bit in. Yes, I'm loosening the collet nut, I even took it off, but still no luck. What am I doing wrong or is this a factory defect? Sorry if this is a stupid question, I'm new at this! I've used a router before, but my shop teacher always changed the bit for us. |
| | #2 |
| Registered User Supreme Forum King | "Collets" is the correct term. Not sure that I can give ya the correct advice at correcting the problem. You may try light sanding of the shafts of the bits, there may be a "burr" preventing them from fitting correctly, and or, try prying the collect tapers open with a small screwdriver. So long as the collect will still fasten to the router, it will still tighten itself onto the shafts of the bits. |
| | #3 | |
| Registered User Forum King | Quote:
So remove both and fix them together before screwing the nut in position Tom | |
| | #4 |
| Registered User New Member | The collet doesn't seem to want to come out. The only thing that I can think to do is to loosen the collet nut, but there doesn't seem to be a way to loosen the actual collet, it's stuck firmly in the piston (I guess- if that's what you were refering to, Tom) |
| | #5 |
| Registered User New Member | My wife bought me a router and I was unable to get the collet out of the shaft. I took the collet nut completely off and with a small flat blade screwdriver and hammer GENTLY tapped the side of the collet and it came out of the shaft. I put it all back together with a straight bit, routed a piece and when I tried to change the bit it was stuck again. Nothing I tried would get it out. Needless to say the router with bit still in it went back to Lowes and I bought a Porter Cable. Not sure if I can say what brand it was (starts with H) but the new Porter Cable has had no problems. KenW |
| | #6 |
| Registered User Forum Geek | Hi: If none of the bits fit, I would take the router back to the store and get a new one. Take some of the bits with you and show it to them. It might be a good idea to get a different brand router, it may cost a little more but a good router will last a long long time. Woodnut65 |
| | #7 |
| The Router Guys Forum King | Take the router back and ask the store to show you how it works? Sounds like a defect to me.
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. |
| Already Problems | neuschu | Introductions | 7 | 01-22-2008 11:32 PM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 07:59 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest - VOTING STAGE!! | Mark | Contests Archive | 13 | 11-05-2006 03:23 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 01:02 PM |
| New Router my way | reible | General Routing | 14 | 06-10-2006 11:19 PM |
