Rate This Thread - rule of thumb for variable speed?.
Thread Tools Display Modes
Old 01-10-2006, 04:23 PM   #1
rprice54
Sr. Member
rprice54's Avatar
rprice54 is on a distinguished road
Default rule of thumb for variable speed?
So I'm enjoying my new PC router, it's my second router but first serious attempt at more than just basic edge-routing. I knew from trolling around and reading a couple of books that I wanted to get a variable speed router- so I did.
I was just wondering if there was a general rule of thumb re:ratio of speed to bit size. I know my drill press has a little chart next to the gears that helps me choose the speed based on the size of the bit and type of material. My manual just basically says, 'your router has a variable speed control between 10,000 and 27,000 rpm. enjoy.' okay, so I added the last part...
rprice54 is offline   Top - Reply with Quote
Old 01-10-2006, 07:13 PM   #2
delroy33
Supreme Forum King
delroy33's Avatar
delroy33 will become famous soon enough
Hi
Here are sugested RPMS for different router bit diameters
1" -- 1 1/4"--24000 rpms
1 1/4" -- 2" - 18000 rpms
2" -- 2 1/2" - 16000 rpms
2 1/2 -- 3 1/2" - 12000rpms
roy
start square, finish square
delroy33 is offline   Top - Reply with Quote
Old 01-11-2006, 05:59 AM   #3
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi: Rule of thumb says the larger the bit the slower the speed of the router. You certainly don't want a large 2-3 inch bit to come apart at high speed, it can cause some serious damage, to the router, your shop, and to the operator. Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 01-11-2006, 05:50 PM   #4
rprice54
Sr. Member
rprice54's Avatar
thanks
Variable Speed vs. Fixed Speed Phillip K General Routing 24 07-12-2008 10:29 PM
How do you tell a router's speed??? allthunbs Table-mounted Routing 11 07-07-2008 03:08 PM
Router speed controls RustyW Starting Off 1 12-29-2005 06:42 AM
"What is it?" #138 reible What is it? 10 07-18-2005 09:35 PM
variable speed routing Dean VV Table-mounted Routing 3 03-23-2005 10:12 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103
