| This is a discussion on Fitting Of Fence On Triton 2000 Workcentre within the General Routing forums, part of the Routers category; Hello there, Hope I'm in the right place to ask this question. Started to assemble ... |
| | #1 (permalink) | ||
| Registered User ![]() |
Hello there, Hope I'm in the right place to ask this question. Started to assemble my Triton 2000 Workcentre today. When I got to fitting the fence, on one side I had to slacken off the nuts on the springs at one end. So the arm would slide in,the other arm went in fine. I can lock the fence in position. I'm not sure if I have fitted the fence as well as could be done. Any help would be very welcome. Cheers, Peter. | ||
Sponsored Advertisement - Register now to remove this advertisement.
** Please be sure to read our Disclaimer at the bottom of the page. **
These advertisements are only displayed to guests, register now for your FREE account on the worlds largest router and woodworking community! |
| | #2 (permalink) | |||
| Official Greeter ![]() |
Can't help you, Peter. I only had the Mk3 work centre and had no problem with the fence. You do not say where you live.. Check out this forum... Woodwork Forums They have a special area just for Triton gear. James | |||
| | #4 (permalink) | ||
| | #5 (permalink) | |||
| Forum Contributor ![]() Join Date: Jan 2007 Country: Australia First Name: Harry Posts: 9,635 ![]() ![]() ![]() |
__________________ Harry Nothing but heaven itself is better than a friend who is really a friend. - Plautus | |||
| | #6 (permalink) | ||
Cheers Harry. | ||
| | #7 (permalink) | ||
| Retired Moderator ![]() |
"I've had this table since, would you believe, 2000! " Yea, but its got those funny-looking *metric* numbers on it! ![]()
__________________ Check out that new high-tech cordless router.. wireless and no recharging required!! | ||
Sponsored Advertisements. Register to disable this advertisement.
| | #8 (permalink) | |||
Harry, I see that Carba-Tec has them back on the market. How difficult is it to make sure the fence is parallel to the blade? James | |||
| | #9 (permalink) | ||
Hi Peter Only just spotted this. Do you mean the flat springs that provide some pressure on the two sliding members that attach the fence? They have clamps back and front, but you usually only need to clamp up either the back two or the front two, depending on how close in you want the fence. HTH Peter | ||
| | #10 (permalink) | ||
Using the Triton saw James it's a piece of cake, set the fence so that it reads zero in-feed and out-feed and adjust the cams so that the blade just touches the fence front and back. If on a test cut the wood tightens or loosens during the cut, slight further adjustment is needed but from memory, the initial set-up was accurate and I haven't touched the setting in all these years and if I set both ends of the fence to 200mm, then the piece of wood is exactly 200mm. For a pressed steel table, the results are remarkable. Often at wood shows when I see magnificent looking table saws I become tempted, then I remember what a perfect job the Triton does and the temptation vanishes. I do recall that when I bought the work-centre I fitted my AEG saw which took over half a day and I still wasn't happy with it so went out and bought the Triton together with the rise and fall accessory (the latter causing me great difficulty to understand the instructions until my granddaughter who would have been about 12 at the time said something like " granddad, do you think it means................"and it did!)
| Face Lift for the Router Fence | bobj3 | Jigs and Fixtures | 8 | 04-07-2013 09:21 AM |
| Mule Accusquare rip fence M1050 | westend | Tool Reviews | 6 | 09-13-2010 08:59 AM |
| Some Thoughts on Fence Control | Gilbear | Table-mounted Routing | 21 | 04-16-2010 05:38 PM |
| A Poor Man's adjustable Positioning Fence | Stefang | Table-mounted Routing | 8 | 02-26-2010 03:22 AM |
| Important information regarding TRITON | harrysin | Lobby | 1 | 01-05-2010 08:08 PM |
