| | #1 |
| Registered User New Member | Hello all I am a new member and just bought a PC 893 kit with both fixed and plunge bases. I bought a piece of melamine to build a router table and got the plate from Rockler. I also bought Rockler's template guide set. When I started to make my pattern for the plate cutout, I really looked at the guides for the first time. The barrel on (most) of the guides is too long for my preferred pattern material. So I returned the set to Rockler. SO, my question: Is there a template guide set availabel that has 1/4" barrels (for tempered hardboard or quarter ply)? Or, should I just plan on making all my patterns out of thicker material? Or, Is there an easy way to cut the long templates to the depth I would like. I could almost imagine cutting the brass on a wood lathe with a parting tool, but thats probably not a good idea. Thanks for any and all tips Tony |
| | #2 | |
There are a couple of active links on this general subject: http://www.routerforums.com/showthre...3&page=1&pp=10 www.routerforums.com/showthread.php?t=147 You might want to check them out. Ed | |
| | #3 |
| Marine Engineer Forum King | You can make your patterns taller by adding strips underneath them, which also has the advantage of preventing the cuttings from building up along your templates. I like using thicker stock for some templates, because it holds up better over time, but it can be a pain to use. My router compass, for example, is 1/2 in poplar. It has been used a lot, and all the holes are still perfect. If your brass template guides are just a hair too long, a quick pass on the sander or a file will take the extra length off in a hurry, just make sure you don't use that sanding belt/disc for anything else. Make sure you put a chamfer on it after you finish, so you make sure that the burr left over from machining doesn't change the diameter of your guide.
| | #4 |
| Registered User Forum King | I construct my templates from 9mm -12mm material I also laminate them both sides Tom |
| Template Guide sizes | mftha | Guide Bushings and Templates | 11 | 06-04-2008 06:35 PM |
| template guide and 1/2" collet | pab | Portable Routing | 4 | 08-11-2006 07:59 AM |
| Porter-Cable template guide no where to be found | jnam | Portable Routing | 5 | 07-21-2006 08:54 PM |
| Porter-Cable template guide no where to be found | jnam | Jigs and Fixtures | 3 | 02-21-2006 08:15 AM |
| The use of template guides (Guide bushes) | template tom | Portable Routing | 28 | 12-04-2004 09:18 PM |
