Thread Tools Display Modes
Old 02-28-2006, 12:29 AM   #1
wanart
New Member
wanart is on a distinguished road
Default Spline vs. Tongue & groove
As a novice woodworker I'm trying various methods. A while back I used a slot cutter and spline material to join two pieces of plywood on a long edge. It worked well. In my current project, a desk-side table with two shelves, I sought to edge the 3/4 plywood with 3/4 pine and I was determined to accomplish it with a tongue and groove joint using the same 1/4" slot cutter. I'm getting it done, but it seems like a lot more effort in both measuring and setup than simply running the same slot in both plywood and pine, and then fitting the spline. To do the tongue I ran a rabbit bit and had to set separate heights for the face and back of the pine because it is a little bit thicker than the plywood. I was thinking about ordering a matched set of slot cutters (one for the groove and one for the tongue), but that brings me back to the simplicity of the spline.
So here are the question for you more experienced woodworkers:
1. Is tongue and groove superior to the spline?
2. If the spline is just as good, is MDF acceptable or should I use plywood because it's surface adheres glue better? If so I think I should get some plywood sized slot cutters.
Thanks in advance.
Art
wanart is offline   Top - Reply with Quote
Old 02-28-2006, 07:22 AM   #2
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi: As to your question of tongue and groove, they are both strong joints and I consider them equal. If you have a planer you could reduce the pine to the thickness of the plywood, and use either joint. MDF can be used for shelves and edge banded the same as plywood glue will hold the pine to the MDF. Another route you could take is the use of biscuit joinery to add edge banding to your projects it's fast accurate and very strong. If the bottom of something will not show even pocket screws can be usd effectively. Hope this helps, it's just my opion. Woodnut65
Woodnut65 is offline   Top - Reply with Quote
New to the forum - Advise PLEASE about Tongue and Groove Flooring Darby Introductions 7 03-25-2007 05:07 PM
Sommerfeld's Tongue and Groove? ShaneB Table-mounted Routing 3 06-13-2006 12:02 AM
Tongue and groove bits archer_456 General Routing 4 02-18-2005 06:51 AM
Forgot a groove - now what? Scotty General Routing 9 10-23-2004 03:35 PM
