| | #1 |
| Registered User Supreme Forum King | I keep seeing Bob and Rick reaching down and turning the vacuum on and off, are a lot of you doing that? The reason I ask is that sometime ago I picked up what was called a power tap at a Sears hardware store. It has Craftsman on the front and is gray. I have one on my computer system to turn on and off printers/scanner/etc when I turn the computer on, and another for my router table. On the router table I have a power strip into which I plug the power tap. The power tap has two accessory and one power tool outlet. I put a short dropcord in to the power tool plug and the router gets plugged into the end of the drop cord. In one of the accessory plugs I plug in the vacuum. When the power is turned on the router the vacuum automaticly turns on (the power switch on the vacuum is left in the on position). Now I spend more time thinking about what I'm doing with the router and less about did I or didn't turn on the vacuum. Anyone else have a system like this? Any other sources of this sort of power tap? Ed |
| | #2 |
| Registered User Sr. Member | No I just reach down and turn the vacuum off ... maybe I should look at one of those and save my back a wee bit ....
__________________ The speed of light travels faster than the speed of sound, that's why people appear intelligent until they open their mouth ... |
| | #3 |
| Registered User Forum Fanatic | Thats what I use on my table saw and on my radial arm saw. I have a shop vac dedicated for each of these two machines as I frequently move back and forth between the two. I have a third vac that I move around to the router table, band saw, mitre saw, etc. Peter |
| | #4 |
| Registered User Dedicated Member | I use one of these with my DC system.All my machines are connected with blast gates. http://shop.woodcraft.com/Woodcraft/...463225B2847CEC
__________________ JH |
| | #5 | |
| Registered User Sr. Member | Quote:
| | #6 | |
Ed | |
| Vacuum Clamping | woodapple | Jigs and Fixtures | 16 | 11-27-2008 05:38 PM |
| Outlook Express problems | BrianS | Lobby | 6 | 01-06-2008 08:23 AM |
| Elbo Hollowing System | mit-ch | Woodturning and Lathes | 6 | 11-11-2007 06:15 PM |
| Jet Tablesaw extension with Jessem RouterLift System | A-Pat-Co | Table-mounted Routing | 8 | 04-11-2007 09:54 PM |
| Need advice on vacuum? | Chipper | Table-mounted Routing | 8 | 02-25-2005 02:59 AM |
