| | #1 |
| Registered User Forum Geek | Can someone explain Up / Down Spiral bits? I have several options in Seattle with Rockler, Grizzly and an Amana dealer. I need to make some good mortises. I want to buy 1 by Wednesday. Thanks -Derek |
| | #2 |
| Registered User Supreme Forum King | Hi, You can use the search feature to look up a lot of posts on the subject but this might be a good start: www.routerforums.com/showthread.php?t=199 Ed
__________________ Sometimes you get, and sometimes you get got. Last edited by reible; 07-15-2006 at 01:55 AM. |
| | #3 | |
| Registered User Forum King | Quote:
There is no doubt the spiral cutter is better than the ordinary straight cutter but I havew been routing Mortices for years with the less expensive straight cutter . So save yourself some cash Tom | |
| | #4 |
| Registered User Supreme Forum King | UP spiral bits pull the chips up out of the cut (towards the router) - DOWN spiral bits push the chips into the cut or away from the router. I've never had an application for Down spiral bits although there must be or why make them - I use UP spiral bits a lot - particularly for mortises. I'd recommend UP spiral for what you're doing - get a good one and you'll love it. |
| | #5 |
| Forum Contributer Supreme Forum King | Fibertech Spiral SOLID CARBIDE BITS Downcut bit is for hand held router applications. Upcut bit is for table mounted router applications. 2 flute flat bottom cutters. Top quality micrograin solid carbide. Will cut faster, smoother and stays sharper longer. Produces a very clean, fast and accurate cut with minimal chatter. Upcut spiral helps remove material. Ideal for making mortise and tenon joints. Downcut spirals help hold the material in place while using handheld routers. Will plunge cut and plane edges. Eliminates chipping at the top of the cut. Ideal for soft & hard woods, plywoods & composites, Bj ![]() |
| | #6 |
| Forum Contributer Supreme Forum King | Fibertech here's a link or two from the RouterForums web page. MLCS Router Bits http://www.mlcswoodworking.com/shops.../bt_solid.html http://www.mlcswoodworking.com/shops...routerbit.html Bj ![]() |
| | #7 | |
| Registered User Forum Fanatic | Quote:
| | #8 |
| Forum Contributer Supreme Forum King | Hi Charles I know your the Pro. all I know is what I read. Can you please post a link to your web page on the same thing I would like to read it also. Thanks Bj ![]() see below ▼ |
| | #9 |
| Registered User Forum Fanatic | No Problem Bj: Spirals From Freud |
| Cmt 1/4 spiral bits | rich1 | Table-mounted Routing | 1 | 02-29-2008 03:02 PM |
| MLCS spiral bits | rich1 | General Routing | 3 | 02-15-2008 09:09 PM |
| Spiral Bits | RustyW | Router Bits - Types and Usage | 5 | 08-18-2007 11:47 AM |
| Spiral bits? | archer_456 | General Routing | 6 | 04-11-2005 11:31 PM |
| Spiral Bits | ejant | General Routing | 4 | 02-09-2005 08:15 PM |
