Thread Tools Display Modes
Old 04-24-2006, 10:32 PM   #1
dogman
New Member
dogman's Avatar
dogman is on a distinguished road
Smile sign making
Could someone please direct me to some infomation on making wooden signs with a Router. I have seen these done at craft shows and would like to try it. I have a bench mounted Ryobi Router.
Dogman :
dogman is offline   Top - Reply with Quote
Old 04-24-2006, 11:05 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
DOGMAN
You will need to use a plunge router with a jig or two.
From Sears or the links below.
If you are real good with your hands you can do it free hand but it takes a bit of time to get it down right ( it's a art ) but the jigs will do most of the time.
http://www.milescraft.com/
#1206 SignCrafter with TurnLock
http://www.milescraft.com/router/1206.html
Hope this helps
Bj
Old 04-24-2006, 11:12 PM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
dogman
Here's a link to buy it from.
http://www.amazon.com/gp/product/B00...lance&n=228013
Bj
Old 04-25-2006, 01:57 AM   #4
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Dogman, the sign making kits are available from several manufacturers, and there are some important differences. The least expensive is the Craftsman, I believe the most expensive is from Lee Valley. They are all the same with the exception of the length of the upper and lower connecting rods; this is important since the Craftsman kit will allow only one average length word and the others will allow for more. I own a Craftsman and would buy one of the longer kits to save on set up time. Another item to think about: I would not use the plastic guide bushings that come with the Craftsman kit. They flex and allow the cutter to wander a bit. Use brass guide bushings and you will get great results.
Old 04-25-2006, 12:05 PM   #5
RStorment
Jr. Member
RStorment is on a distinguished road
Dogman:
I make signs freehand... you can make them much more personalized by sketching the lettering/design with a pencil and following them with a plunge router. I use a 1/4" V-groove bit, along with a 2" wide access clear baseplate for better viewing. Raising/Lowering the V-groove bit will allow you to change the depth and width of your cuts at the same time. It takes a LOT of practice to make your cuts straight, but it is well worth it!
-Ryan
RStorment is offline   Top - Reply with Quote
Old 04-25-2006, 12:19 PM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Dogman
Here's a snapshot of one of many I have made.
This one is by the front door just to let people know who going to open the front door.
The Boss or me.
Bj
Old 04-25-2006, 12:40 PM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Dogman
Here's a pull chain door knocker that's right by the sign, it lets people know that a old fart wood worker will be coming to the door...
This snapshot is just for kicks..
I thought you would enjoy it.
Bj
Old 04-25-2006, 05:55 PM   #8
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Door Knockers, just incase someone wants to make one.
Not the same one but some good ones.
http://www.runnerduck.com/door_knocker.htm
http://www.ext.nodak.edu/4h/programs/pecky.htm
http://topscot.com/TheTreeHouse/Detail.asp?ID=1010778
http://topscot.com/TheTreeHouse/Detail.asp?ID=1010777
http://topscot.com/TheTreeHouse/Prod....asp?ID=101012
Bj
Old 04-26-2006, 10:56 AM   #9
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Dogman
Here's one you may want try out.
I have and it works great for making a signs.
I use a roto-zip tool ,a older one, you can just cut so many holes in drywall with it so I put the 1/4" collet in and chuck up a 1/4" or 3/8" v-grove bit and a off and on switch on the floor and use it to make signs.
Because the older type is lighter than the new type it works great for free hand signs.
I also use a rpm speed control box on it ,so I don't burn up the bits up and put burn marks in the stock.
The floor switch comes in to play if I need to stop and then start up again.
Roto-Zip from a pawn shop for 20.oo bucks,floor switch for 22.oo bucks,speed control for 12.oo bucks and a bit at 6.oo bucks and you are set to make signs.
I have tried the moto tool out with the drive cable but it didn't work as well as the Roto-Zip becase of the mass of the roto-zip tool, it helps with control of the sign cutting.
Hope this helps with your sign cutting
Bj
Old 05-04-2006, 05:24 AM   #10
mailee
Forum Fanatic
mailee is on a distinguished road
Hi Dogman, I make signs with a hand held 1/4" router and find it relaxing. I do not use any templates but freehand them. It is easier than you think and with a little practice you can make professional signs in no time. i have just sent an article off to one of the magazines here in the UK on a 'how to' If you want to know more just send me a message.
mailee is online now   Top - Reply with Quote
sign making Andy4810 Introductions 8 07-05-2008 07:26 AM
Sign Making Lou G Introductions 2 01-05-2008 08:13 AM
Sign Making cathy Introductions 8 11-20-2007 09:40 AM
Sign Making cathy Introductions 3 11-12-2007 12:31 PM
Wooden sign making tigger Introductions 5 08-16-2007 06:31 PM
