| This is a discussion on Router Speed Control . within the General Routing forums, part of the Routers category; I need to know if I buy a speed control in the US (120 volts), ... |
| | #1 (permalink) | ||
| Registered User ![]() |
I need to know if I buy a speed control in the US (120 volts), how can I use in 220 volts.And also if anyone knows any routers working in 220 that are sold in US. Thanks for all the opinions and help!! | ||
Sponsored Advertisement - Register now to remove this advertisement.
** Please be sure to read our Disclaimer at the bottom of the page. **
These advertisements are only displayed to guests, register now for your FREE account on the worlds largest router and woodworking community! |
| | #2 (permalink) | ||
| Forum Contributor ![]() |
Hi sergio Sorry to say you are SOL on the speed control box,,, Porter Cable makes a 220 volt router but it's not the same as your 220 volt setup..You may want to check out some of the UK outlets for a router..(Trend ) ======
__________________ "It's fine to disagree with other members as long as you respect their opinions" MANY,MANY help files on John's web site http://legacy.woodshopdemos.com/menu2.htm Sommerfeld Tools ,Videos http://www.youtube.com/channel/UCT-n...RWaEpMA/videos | ||
| | #4 (permalink) | |||
| Registered User ![]() Join Date: Sep 2010 Country: Canada First Name: Charles Posts: 1,920 ![]() |
| | #5 (permalink) | ||
I’m originally from Argentina living for long time in the US. As it’s already said the voltage in Argentina, is 220-240, bring it down to 110 is very simple with a transformer and they are easy to find locally. The problem with electronics is the frequency and I mention this because I have taken over the years some electronic equipment that work OK and some others that do work but kind of erratic, those having a electronic timers have problems, they all run slow and I assume that is because the clocks and timers are controlled with the freq 60 Hz. US and 50 Hz Argentina. for example a washer or dryer when it says will take 20 minutes will be about 24, not much of a problem. This was explained to me that way by an LG support technician. Regular routers work ok, I took one there years ago and is doing ok, I guess the electronic speed control should be the same. | ||
| | #6 (permalink) | |||
| | #7 (permalink) | ||
| Official Greeter ![]() |
G'day Sergio Welcome to the router forum. Thank you for joining us
__________________ James Sydney, Australia. I don't mind if other members disagree with my comments. I don't profess to know everything, and I may learn something new. | ||
Sponsored Advertisements. Register to disable this advertisement.
| | #8 (permalink) | |||
| | #9 (permalink) | ||
Hi Charles The potential difference between +55 volts and -55 volts is 110 volts, which is what our industrial site power tools run on. I've found that most 115 volt US tools with universal motors will run on that quite happily unless they have some sort of frequency-based speed controller. The UK and Ireland are probably the only places in the EU which have 110 volt power tools on building sites (and other restricted areas such as railway lines, etc). My understanding is that if one live is exposed and you accidentally touch it the 55 volts earthing through your body cannot kill you, but as some people are killed every year testing 9 volt bicycle batteries on their tongues, maybe I'm wrong there. So it is supposedly intrinsically safer. Maybe. The rest of the EU, however, doesn't play that game and instead insists on the standard 220 volts (live + neutral) with an RCD to protect each circuit. We normally get an MCB or RCD per circuit on larger transfornmers so maybe the health and safety brigade/insurance brigade are a bit more belt and braces here in the UK. What I do know is that it costs me more to buy some of my work tools and that not everything is available in 110 volt form. The only other thing I can say about 110 volt site tools is that they are useable outside safely when it's a bit damp with minimal risk of electrocution. By that I don't mean standing up to your oxsters in water core-drilling a wall in the middle of a monsoon, but certainly I've been out there jigsawing a hardwood shop frontage to scribe it in whilst the rain is spitting and the pavement is still wet. So far, at least, without problems! I suppose that it's the transient nature of construction work (be it domestic kitchen fitting, commercial bar fitting or building a skyscraper) which means that most of the problems will occur in the extension cables which do tend to get dragged all over the place, run-over by trucks, etc rather than problems in the tools themselves Regards Phil | ||
| | #10 (permalink) | |||
Hi Phil and Chuck ??????????????????????? ========== Quote:
__________________ "It's fine to disagree with other members as long as you respect their opinions" MANY,MANY help files on John's web site http://legacy.woodshopdemos.com/menu2.htm Sommerfeld Tools ,Videos http://www.youtube.com/channel/UCT-n...RWaEpMA/videos | |||
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 14 | 05-23-2012 04:51 PM |
| Freud FT3000VCE 3-1/4 HP Variable Speed Plunge Router | Bridge | General Routing | 9 | 11-01-2010 08:18 PM |
| "What is it?" #138 | reible | What is it? | 13 | 10-26-2009 09:07 AM |
| Router speed | Allejo | General Routing | 6 | 10-17-2009 06:54 AM |
| Old Glossary Terms | Mark | RouterForums.com News & Feedback | 0 | 10-14-2008 01:30 AM |
