Thread Tools Display Modes
Old 05-09-2006, 01:14 PM   #1
wanart
New Member
wanart is on a distinguished road
Question Need advice on exterior door making
I have an old adobe house with nonstandard exterior door sizes and I need to replace the storm door. I tried cutting down a solid core door from Larson but that exposed the particleboard core & it wicked moisture & decomposed. I want to reuse the screened window from the Larson door and build a new door from composition decking.
The problem is the joinery. Stile and rail bits for entry doors seem to start at 1 3/8". The thickness of the Trex composit decking available to me is 1 3/32". I haven't bought the decking or the bit(s) yet so I'm wide open to ideas. What can I build a door out of and how do I join it together?
Thanks for your help.
wanart is offline   Top - Reply with Quote
Old 05-09-2006, 02:56 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
wanart
Do you want to make a new Exterior Door or a storm door ???
Most Storm doors are Not 1 3/8 " thick or 1 3/32 most are 1 1/2" if it has the glass and screen type some are just 7/8" without glass insert.
Can you post a picture or two and I'm sure some one will help with your question.
Just a note Trex composit decking is not flat, you can plane it like wood BUT it will not take on glue very well but you can use poly. base type glue on it.
I just made a mail box post with the Trex stock because you can put in the ground and it will last forever..
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-09-2006, 04:09 PM   #3
Senior Moderator
Supreme Forum King
Mike has disabled reputation
You can create your own tongue and groove using a 1/4" straight cutting bit. Mark your material and plow out the 1/4" groove on the stiles. Next make rabbit or rebate cuts on the ends of the rails to fit your groove.
Old 05-09-2006, 06:42 PM   #4
Gilbear
Supreme Forum King
Gilbear's Avatar
Gilbear is on a distinguished road
On an old house (100 years plus) I use to have (or rather, it had me) the screen doors and storms were made with bridal joints and then pegged - that could be easily done with straight cut bits as Mike was suggesting - and the look may just be in keeping with how I picture an adobe house - although it sounds like you may be wanting to get away from traditional materials - just a thought anyway!
Gilbear is offline   Top - Reply with Quote
Old 05-09-2006, 10:42 PM   #5
wanart
New Member
My intent is to reconstruct the storm door that is falling apart. The existing door is about 7/8" thick. It's a 3/4" particleboard core with thin laminates on both sides. What I want to do is rebuild it of some material that is as waterproof as I can get. That is why I'm looking at the Trex composition decking material.
I didn't realize glue would be a problem. I thought that composition, like particle board and MDF, had a lot of glue in it.
I thought about tongue and groove, but the stile & rail configurations look like they would be more stable. I'm also wondering about biscuits. I haven't tried them yet so I don't know if they would be viable in this situation. Anyone have any comments?
Gilbear, what is a bridal joint? I'm not overly concerned with a traditional look, what works is more important, but the Trex decking is made to look like a wood plank so it would be in keeping with the adobe.
Old 05-10-2006, 12:03 AM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
This is what I would do.
Plane down one side only to the 7/8" then use a mortise and tenon joints on the top and bottom and the center stile, 2" long tenons then 4ea. 5/8" long plastic dowell pins in ea.joint but can only be seen from the inside of the door.
Then rabbit the inside of the door for the glass/screen ,then mortise for the hing.
This should keep rustic adobe look on the out side of the door.
Definitions of Trex
Trex is a brand name of composite material and it is a registered trademark of Trex Company.
Trex is made from reclaimed plastic and wood waste & epoxi and resin.
Resin
Any of numerous physically similar polymerized synthetics or chemically modified natural resins including thermoplastic materials such as polyvinyl, polystyrene, and polyethylene and thermosetting materials such as polyesters, epoxies, and silicones that are used with fillers, stabilizers, pigments, and other components to form plastics.
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-10-2006, 12:17 AM   #7
wanart
New Member
Bobj3
I didn't really follow that, but I don't have a planer anyway. What would be the advantage of making the material thinner?
Old 05-10-2006, 12:34 AM   #8
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
wanart
you said "The existing door is about 7/8" thick"
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-10-2006, 12:48 AM   #9
Senior Moderator
Supreme Forum King
Wanart, Biscuits are fine for furniture indoors but a poor choice for outside use. In order to keep things simple you can build a simple half lap joint on each corner. Use a straight bit to remove half the material from each piece, place the two pieces together and you have a perfect match. You would want to use either Titebond 3 or a polyurethane glue for this project. Gorrila glue is one popular brand name. Be sure to measure the long diagonals so you are square when you clamp this up. Once your glue dries you will want to install dowels through the joint to keep it pinned in place. (Minimum of 3, 4 preferred) Be sure to use hardwood dowels such as oak, cherry or walnut. You may want to use a contrasting color rather than trying to make them match your composite. I would seek advice on the finish from a local building supply company. They will steer you to the products that will work best in your area.
Old 05-10-2006, 01:50 AM   #10
reible
Supreme Forum King
reible's Avatar
Before you get to excited about Trex.... I don't think it will work for a door....
"Can Trex lumber be used for deck posts or joists?
No. While Trex lumber is tough and durable, it does not have the same stiffness as wood. Therefore, it is not intended for use as a load bearing post, joist or any other primary load-bearing member."
The prime word here is "same stiffness as wood".
Ed
Sometimes you get, and sometimes you get got.
Cnc advice needed mderzio CNC Routing 5 04-09-2008 08:32 AM
need advice for inserting rosseau router plate into bench dog promax cast iron table sf_basilix Table-mounted Routing 7 02-21-2008 07:00 PM
Advice sought on router options jcarter137 Introductions 2 02-02-2008 09:57 PM
Seeking advice - safety and feasibility trex021 Shop Safety 5 04-09-2007 04:45 PM
Some advice before going to see the Dr. Joe Lyddon Lobby 1 02-13-2007 09:18 PM
