| | #1 |
| Registered User | I am making raised letter signs. I am using a trim router from homier and a straight bit. My problem is the bottom of the sign has trails and is uneven. Am I using the wrong bit if so what should i use? I am new to woodworking and any info would be greatly appreciated. Thanks |
| | #2 |
| Forum Contributer Supreme Forum King | Dleveque You may want to drop a email or PM to Alan (mailee) for a tip or two looks like he has it down right. see link below ▼ http://www.routerforums.com/showthre...ghlight=mailee Bj ![]()
| | #3 |
| Senior Moderator Supreme Forum King | For this application an upcut spiral bit would give a better finish. This type of bit has cutting edges on the end of the cutter where a straight cutter does not. Another consideration is providing enough support for your router base so it will ride evenly.
| | #4 |
| Forum Contributer Supreme Forum King | Dleveque Just a add on Note*** Don't forget the Table Top Jig Saw/Scroll Saw, you can cut the letters or numbers out and then glue them in place. (with a good outside glue,T-Bond) Or cut all the numbers and names as one item ,this will give it the look of free cut with a router . (Raised Letter Sign) Bj ![]()
| Question on raised panels | kylawyer | Table-mounted Routing | 5 | 03-08-2008 11:44 PM |
| Raised Panel Vertical or Horizontal Sets? | WoodyRon | Router Bits - Types and Usage | 8 | 11-24-2007 03:54 PM |
| Router for raised panels | Jtomwoods | Table-mounted Routing | 3 | 08-21-2006 01:59 PM |
| What size of Raised Panel Bit? | SandyT | Table-mounted Routing | 29 | 07-17-2006 11:34 PM |
| Question about raised panel router bits | LBrandt | Table-mounted Routing | 2 | 07-08-2006 10:47 AM |
