| | #1 |
| Registered User Forum Fanatic | Took a while to get around to pics on the mounting method that I used. Instead of the sabre saw mounting(like yours) I had a molding head which I no longer use hence the guard for same was utilized in my mounting of the router. I took the base off the old Craftsman made up a wood clamp to attach the router to the backplate. I had to retain the router handles due to the intregal switch. The whole assy slips on in place of the saw blade guard. Lee |
| | #2 |
| Registered User Forum Fanatic | Rats....the pics did not come through Lee |
| | #3 |
| Registered User Forum Fanatic | Will try again. Lee |
| | #4 |
| Forum Contributer Supreme Forum King | Thanks Lee Looks like they both work about the same way .The only error I run in to sometimes is keeping the RadioArmSaw table true with the arm of the saw, if I run in on a 45deg. slot. it will not be true on the outer end, so I need to shim the stock,just a bit. But other than that it works great...for the hard router cuts I sometimes make. http://www.routerforums.com/attachme...achmentid=2656 http://www.routerforums.com/attachme...achmentid=2657 http://www.routerforums.com/attachme...achmentid=2658 http://www.routerforums.com/general-routing/2742-will-my-old-router-do-job.html Thanks again for the snapshots. Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 06-24-2006 at 06:11 PM. |
| | #5 |
| Registered User Forum Fanatic | Keeping the table top parallel to the arm of the saw was a problem with me as well mainly because I store a lot of stuff on the wall behind the saw & now & then I would inadvertantly stand on the saw table when accessing a tool off the wall. I changed out the washers on the bolts used for adjusting the table for those thingy washers that are all serrated around the outer edges. Now I think I could tap dance on the saw table without it moving on me. Lee |
| | #6 |
| Forum Contributer Supreme Forum King | Thanks Lee I will give that a shot... ![]() Bj ![]()
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 09:54 AM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 07:59 AM |
| Problem mounting Dewalt Router to Caftsman Table Saw | apollo2000 | General Routing | 8 | 05-22-2007 07:42 PM |
| RouterForums.com and Oak-Park.com - September 2006 Contest - VOTING STAGE!! | Mark | Contests Archive | 13 | 11-05-2006 03:23 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 01:02 PM |
