Help
IconIt appears you aren’t a registered member of the Router Forums community. Why not spend less than a minute and register for the oldest and largest router and woodworking community on the web! Join in over 29,500 discussions with over 65,000 woodworkers. If you’re an experienced or beginner woodworker, your questions and knowledge is always warmly welcomed by our community. Register now for your FREE account!
Bosch plunge router handle loose
This is a discussion on Bosch plunge router handle loose within the General Routing forums, part of the Routers category; Hi everyone, I do a lot of lurking here, still learning, but now I have ...
Old 05-15-2011, 07:00 PM   #1 (permalink)
rastus's Avatar
First Name: Paul
rastus is on a distinguished road
Default Bosch plunge router handle loose
Report Post Report This Post!
Hi everyone, I do a lot of lurking here, still learning, but now I have a question or should I say a problem with my Bosch. I bought the 1617vs from Amazon last year in March. A couple weeks ago I noticed the handle on the plunge base was loose, so I removed the outer half and tried tightening the inner screw but found the threads in the hole are stripped. Dose anyone know if and how I can fix this? Without the handle the screw seems to hold, so I'm going the hardware store tomorrow and find a longer one to see if that works. I just wanted to know if anyone else has had this problem and what you did to fix it. Thanks for reading.
Paul
rastus is offline
Sponsored Advertisement - Register now to remove this advertisement.
** Please be sure to read our Disclaimer at the bottom of the page. **
These advertisements are only displayed to guests, register now for your FREE account on the worlds largest router and woodworking community!
Old 05-16-2011, 09:38 AM   #2 (permalink)
Tempest is on a distinguished road
Depending how much metal is in the area, you might be able to go up one size screw via a tap. The existing screw is most likely metric, but you might be able to use a fractional screw that is slightly larger.
Tempest is offline
Old 05-16-2011, 06:37 PM   #3 (permalink)
rastus's Avatar
First Name: Paul
Thanks for the reply Tempest. I picked up a longer bolt of the same size threads and that seems to have done the trick since the hole was deeper than the original bolts length, at least 1/4".
Paul
rastus is offline
Old 05-17-2011, 12:42 AM   #4 (permalink)
Forum Liaison
Mike is a jewel in the rough
Paul, it wouldn't hurt to use a thread locker on the bolt. Routers have lots of vibration. My 1617's have been trouble free for many years.
Wanted: Bosch 1617 Plunge Router Dust Extraction Hood jimcrockett Woodworking Classifieds 0 03-05-2011 02:25 PM
Variable Speed Plunge Router Application MJCookSr Table-mounted Routing 2 10-22-2010 05:54 AM
Ridgid R2930 (fixed and plunge base routee) xplorx4 Tool Reviews 13 03-12-2009 02:20 AM
Old Glossary Terms Mark RouterForums.com News & Feedback 0 10-14-2008 01:30 AM
Colt plunge base bobj3 Jigs and Fixtures 19 04-01-2008 07:54 PM
