Craftsman router adjustment is stuck - Router Forums
post #1 of 7 (permalink) Old 06-07-2011, 10:16 PM Thread Starter
First Name: Joseph
I have a 2 hp craftsman router hooked up to a router table. I cannot adjust the depth because it's stuck. The last time I used it, I had a really hard time to adjust it. Is there anyone here with the same problem and can it be fixed short of using a sledge hammer on it.
raynaldb is offline
post #2 of 7 (permalink) Old 06-07-2011, 10:23 PM
G’day Joseph
Welcome to the router forum.
Thank you for joining us
At this stage I would keep away from the sledge hammer.....
What model router are you using?
Sydney, Australia
jw2170 is offline
post #3 of 7 (permalink) Old 06-07-2011, 11:10 PM
mpbc48's Avatar
Welcome Joseph,
My first guess is it's bound up with sawdust.
You think I'm crazy? Wait till you meet my imaginary friends.
mpbc48 is offline
post #4 of 7 (permalink) Old 06-08-2011, 12:34 AM
Hi Joseph, welcome to the forum
Need a model number and is it a fixed or plunge base mounted in there? Odds are it's jammed up with sawdust..likely need to pull it out of the table and give it a good cleaning and lube....wax or graphite. When we get a model number we can pull up a parts explode and look for other possibilities. Good luck
John Schaben
jschaben is offline
post #5 of 7 (permalink) Old 06-08-2011, 09:05 AM
dutchman 46's Avatar
First Name: Howard
Hello! I will assume that it is a router without plunge! They have been bad at collecting sawdust in the adjustment threads. A little air, and working the router up, and down, ever so lightly will help loosen it. It helps to have help to turn the locking wheel up, and down. Or the adjustment, that way You can work the air, and help take a bit of sawdust out of the cavity. The brush that I use it the brush that has stiffer bristles They are used for clean-up when working with auto parts cleaning. I will use a longer wire tie to get the saw dust moving while blowing. Once cleaned, dry it up, but do not lube! Any kind of lubricant will hold sawdust., I hope I have it correct on the type of router You have
John 3:16
dutchman 46 is offline
post #6 of 7 (permalink) Old 06-12-2011, 01:50 PM
First Name: Chris
I agree with Howard about about lubricants but I did find rubbing the router with every day wax found in the canning department at Walmart helps a lot.
Chris
roedercm is offline
post #7 of 7 (permalink) Old 08-15-2015, 01:32 PM
Thumbs down Craftsman router with stuck height adjustment
I have the same problem. Taking it out of the table and cleaning helps but not for long. Any help in keeping the chips out of the gears short of hooking up a vacuum system?
Very frustrating.
Andy in Travelers Rest, SC
Andy in Travelers Rest, S is offline
Human Verification
First Benchtop Router Table, get a plate or go bare? silentblackhat Table-mounted Routing 38 05-30-2012 03:30 AM
Grizzly G1035 Shaper vs Router Table GAVolunteer Table-mounted Routing 11 06-30-2010 07:35 AM
Craftsman Router 17540 jmckin58 General Routing 0 06-21-2010 09:28 PM
Craftsman 2hp professional router table combo... Duane867 Table-mounted Routing 2 01-04-2010 12:12 AM
