Thread Tools Display Modes
Old 07-30-2006, 02:11 PM   #1
coolguy982
New Member
coolguy982 is on a distinguished road
Default Newbie: Need help changing bit on older Craftsman Router
I recently purchased a craftsman 315.17492 1.5 hp router at an auction. I bought some new bits and cannot for the life of me figure out how to change the bit!! The router came with a wrench (shown in attached picture) and has a button at the top that claims to lock the shaft. When I move it over to Locked, the shaft will not lock. I thought all I would need to do is switch it to Locked and then use the wrench to turn the bit loose, but the shaft keeps moving. I tried putting a vice grip on the metal shaft but it would not hold it and it also began cutting into the metal on the shaft.
I should note that the router runs fine. I also tried to turn the router on with the switch in the locked position (just to see if it actually does anything), and the router would not turn on.
Can anyone tell me how to change the bit? Am I missing something simple, or did I buy a piece of junk?
I've attached some pictures of the router for reference.
newbie-need-help-changing-bit-older-craftsman-router-router-002.jpg  newbie-need-help-changing-bit-older-craftsman-router-router-001.jpg  newbie-need-help-changing-bit-older-craftsman-router-router-003.jpg
coolguy982 is offline   Top - Reply with Quote
Old 07-30-2006, 02:50 PM   #2
Hamlin
Supreme Forum King
Hamlin's Avatar
First Name: Ken
There should be a "detent" on the shaft near that button. Make sure that that has engaged in order for the shaft to "lock". You may find that you will have to rotate the shaft til you feel it lock. Don't use the vice grip method, this will only lead to problems further down the road if you ever have to do any repair work on lets the motor. Hope this helps.
Ken
"A VETERAN"
Old 07-30-2006, 03:58 PM   #3
coolguy982
New Member
After I've moved the button to the "locked" position, it doesn't seem to do anything to the shaft. I can still freely rotate the shaft multiple revolutions in either direction without it catching or locking. Any other suggestions?
Old 07-30-2006, 07:47 PM   #4
Hamlin
Supreme Forum King
Hamlin's Avatar
First Name: Ken
You by chance didn't get a manual with it did you? The simplest thing to do would go into your local sears store and ask them... "show me".
I wouldn't say you got a piece of junk. If you feel comfortable in repairing this yourself, simply take the housing apart and look for the "locking" button. The "ear" that sits in the detent may have been broken off not allowing it to work properly, or, take it to either your local sears store or find a local tool repair shop.
Hope this helps.
Ken
"A VETERAN"
Old 07-30-2006, 08:10 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Coolguy982
The Lock device is in need of repair....take it into your Sears Service Center and have them check it out..
But if you have used a pair of vice grips on the motor shaft you may have turned the router into a boat anchor ,out of all the tools you can use this one will damage it more than most.
You can download a parts list (diagram) and use it to give you a hint what you are working on and what to look for in the lock device.
It sounds like it's a power switch and a lock all in one.
Once you see what it looks like inside take it down and you can order the part from Sears and repair the router.
Good Luck
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 07-30-2006, 08:28 PM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Sorry Ken
You and I are thinking on the same lines but it took me longer to get back to the post,I was looking for a parts list, but didn't find one but I did see one that was sold on eBay for 35.oo bucks (router) like new so it may not be worth the repair cost to fix this Sears router.
But that's up to him I think....have a good one.
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
NEWBIE: Craftsman Table and new Milwaukee Router randyn Table-mounted Routing 15 01-24-2005 12:14 PM
