Rate This Thread - email tip for 10/12/04 question.
Thread Tools Display Modes
Old 10-12-2004, 10:44 PM   #1
reible
Supreme Forum King
reible's Avatar
Default email tip for 10/12/04 question
I'm not sure where this should go but here is where I'm putting it.......
BobandRick I see you use the single bit to make the pass down the veneer material. Then you lower it and do the two passes to make the molding. If that is one bit then the top gets used to do all three cuts to the bottom half of the cutter which does just one cut. Is that correct?
Now the real question, is there a reason why you use the butterfly bit over a matched set of edge v-grooving bits?
Ed
Old 10-12-2004, 11:38 PM   #2
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
No real reason to use the butterfly bit over the V-grooving bit. Just looking for other ways to use the router bits that I have.
But if I was to use the V-grooving bit to cut the veneer material, I would match a square piece of solid material between two V-groove veneer cut pieces, glue then rip the two apart leaving triangle shaped pieces for the facing material. Another way to glue solid material to veneer plywood edges.
Rick and Bob
The Router Guys
Old 10-13-2004, 12:37 AM   #3
reible
Supreme Forum King
reible's Avatar
Am I picturing this correct? See attached. How do you get the zero width saw cut?
Ed
Old 10-13-2004, 08:55 AM   #4
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
Yes, I would make the square piece a bit larger to give room for the saw kerf when cutting the pieces apart.
Rick and Bob
The Router Guys
Old 10-13-2004, 06:31 PM   #5
Michael
Member
Michael's Avatar
Michael is on a distinguished road
I believe Bob briefly mentioned this on one of the shows, although I forget which episode it was. I thought it was a great idea, let me thank you now for the tip. Thank you.
Michael is offline   Top - Reply with Quote
a member of 2 years but never posted a question. Here goes...(PC 695/bosch table) routerron Introductions 4 09-19-2006 11:33 AM
Where do I post this type of question? RouterFool Introductions 1 03-30-2006 08:54 PM
craftman router question tsbrewers Table-mounted Routing 7 05-16-2005 05:54 PM
Craftsman Router Question fibertech Portable Routing 4 05-09-2005 04:49 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
