How to Make Wheels - Router Forums
post #1 of 8 (permalink) Old 09-07-2011, 08:29 PM Thread Starter
How to Make Wheels
Wooden wheels accentuate so many things, from wagons to carts to decorative items in your home. Using your router, you can make some very nice wheels for almost any project that you can think of. Video number 110 with Bob and Rick Rosendahl shows how to make custom wheels for your project.
Setup
The setup for this project is just a bit different in that the router is not set up in the table, but goes on top to give you better control. Place a square blank piece of hard wood on another square piece of wood about the size of the hole where the router usually goes. Secure the wood so that it does not move when you begin working the piece. Get your fence, a flat piece of plastic with the shape of a spoke for the wheel cut out, and place on top of the wood that you will be working with. Secure into place with a screw on the outer part of the wood.
Put in a spiral ½” bit in your router, and lock it down about the depth of the wood. Place a one-inch brass guide in the spoke hole, as this will guide you when making your cut.
Step One
Place your router in the plunge position on top of your wood and plastic fence. Make the cut, moving the router from left to right, or in a clockwise rotation. Let the guide follow the spoke pattern in the wood. When complete with the first spoke, lift up the router and set aside. Shake out the debris, take out the screw and move the fence to the next space for the second spoke. Use a guide pin to make sure you are in the right spot and it is tight against the edge of the previous hole. Screw in place and remove the pin. Make the second hole, and repeat this process until all five spokes of the wheel are done.
Step Two
Remove fence and place in the center of the wheel so that the center hole fits right on the holding place in the center of the wheel. Use the router to cut around the end to make a circular wheel. Remove the scrap, and take out your wheel.
Finishing
To finish up your wheel, place the router back into the table, with a ¼ round over bit attached to it. Run the inner spokes around the bit to make a more finished look. Then place a guiding pin next to the bit and do the same for the outside of the wheel. Now you have a wooden wheel that will make any project look great!
Click here to join the Router Workshop!!
learnexperience is offline
post #2 of 8 (permalink) Old 09-07-2011, 08:56 PM
Hi
How about a picture of the wheels you have made ..Pls.
Setup
Step One
Step Two
Finishing
post #3 of 8 (permalink) Old 09-07-2011, 11:42 PM
How large of a wheel can I make using this technique?
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #4 of 8 (permalink) Old 09-07-2011, 11:45 PM
Hi James
12" with the OP jigs..but they don't sale them any more..
post #5 of 8 (permalink) Old 09-07-2011, 11:50 PM
That would make for a small wagon or cart.
Whittier, CA.
jlord is offline
post #6 of 8 (permalink) Old 09-07-2011, 11:59 PM
Hi
Right on Bob R. made a real nice wagon with them I have use them for many jobs like a hot plates for pizza and a tea kart.
Just a note , you can make bigger wheels once you have one template and use it to make your own template(s) with just a little bit of math..
post #7 of 8 (permalink) Old 09-08-2011, 08:23 AM
First Name: Gregg
Make two disks, half the thickness of your wheel, and rabbet the inside edge of each.
Put a correctly sized V-belt around the rabbet, then glue the disks together trapping the v-belt between them and you have a wheel with a very strong rubber tyre - much stronger than wrapping with a piece of inner tube - and doesn't mark floors as badly.
I *think* I got this from a book called "router magic", but not definite - does work really well though.
bigegg is offline
post #8 of 8 (permalink) Old 09-08-2011, 09:27 AM
O Rings work very well also no rabbit needed just a slot for the o ring to sit in..
Size SPL-KT-BUNA, Specialty Kits SPL-KT-BUNA on Daemar Inc.
Vulcanizing O-Ring Kits
You Can Make an O-Ring
Human Verification
  LinkBacks (?)
LinkBack to this Thread: http://www.routerforums.com/general-routing/30345-how-make-wheels.html
Posted By For Type Date
General Discussion : Routerworkshop.net This thread Refback 01-22-2012 07:54 PM
2011 October : Routerworkshop.net This thread Refback 10-25-2011 09:23 PM
General Discussion : Routerworkshop.net This thread Refback 10-19-2011 10:08 AM
Untitled document This thread Refback 10-16-2011 12:38 PM
How to Make a Raised Panel Door learnexperience General Routing 2 09-06-2011 08:39 PM
How to Make a Table Base learnexperience Tools and Woodworking 0 08-11-2011 10:40 PM
How to Make a Pencil Box learnexperience Tools and Woodworking 2 08-09-2011 11:45 PM
Coned wheels dtoggs Jigs and Fixtures 1 08-25-2008 06:15 PM
Jig to make spoons Norm Johnson Jigs and Fixtures 1 10-20-2004 11:02 AM
