| | #1 |
| Registered User | I used to own a Ryobi router and could never maintain a bit centered in a baseplate bushing so I assumed that there was too much slop in the router. So I bought myself a new skil router and made a baseplate using a different router (from work) but the same model. The first time I used a pattern bit I could tell that it was going the slightly cut my brass bushing on the one side. After my second cut it had cut right throught the bushing. Is there something I did wrong or is there something I can do to prevent this? ![]() Thanks Chris. |
| | #2 | |
For further reading check: www.routerforums.com/showthread.php?t=163 I wrote a couple of articals and one is about aligning sub-bases..... Ed | |
| | #3 |
| Registered User New Member | I can recommend the trend uni-base. It fits most routers and comes with a centering tool. The base allows the use of all trend guide bush's. They retail at abot £15.00 (sterling) |
| Mounting Bosch Jigsaw to Router Baseplate - finished | Ladd | Table-mounted Routing | 4 | 02-06-2008 05:47 PM |
| Shelf pin hole jig - reviews and router solution | Greg_R | Jigs and Fixtures | 7 | 12-30-2007 06:18 PM |
| Which hole pattern should I get (plate for a Bosch 1617)? | Nickbee | Table-mounted Routing | 1 | 11-23-2007 06:49 PM |
| Drilling large hole over small hole or vice-versa | simplenik | Tools and Woodworking | 8 | 06-13-2007 07:57 PM |
| Routing a hole | Learning Herb | Tools and Woodworking | 11 | 03-20-2006 04:29 PM |
